Raptor 95, 100 or 150
Old Jul 5, 2010 | 01:38 AM
tburke's Avatar
Default Raptor 95, 100 or 150
Thinking about getting a raptor. The only mod I have is the edge juice with attitude. I'm thinking I should get the raptor 100 but if I get the 150 would that be to much pump?
Old Jul 5, 2010 | 07:28 AM
RAW's Avatar
RAW
As these units have a built in regulator, there really isn't "too much pump". If you go larger now, there is room for more modifications without having to change your lift pump again.
Old Jul 5, 2010 | 01:55 PM
tburke's Avatar
Oh good, then best to go with the 150...Thanks
Old Jul 5, 2010 | 02:13 PM
Billy D's Avatar
Raptors rock
Old Jul 5, 2010 | 02:59 PM
I would do the 150 and replace your draw tube.
Old Jul 5, 2010 | 09:10 PM
tburke's Avatar
Would I need to remove the tank or bed to install the draw tube?
Old Jul 5, 2010 | 11:17 PM
Ya thats the hardest part of the install.
Old Jul 5, 2010 | 11:40 PM
tburke's Avatar
Ok, thanks for your help.
Old Jul 6, 2010 | 08:01 AM
RAW's Avatar
RAW
I didn't find it too bad when I put my FASS and Draw Straw in. I had the tank very, very low on fuel which helped a lot. A couple 4x4's and a floor jack is all I used to raise and lower the tank. There is a frame cross member that needs to be unbolted and swung out of the way, and then it's free to come down. If my memory is correct.
Good luck!
Old Jul 6, 2010 | 08:38 AM
rngperf's Avatar
FormerVendor
Ditto on the other posts. You wont go wrong with going big now, who knows what you might add later? You never know what you might win on one of the give-a-ways. Too much pump is like building too big of a shop, No such thing.
