runnin the valves
Old Jul 4, 2010 | 09:39 PM
junkyardkid69's Avatar
Default runnin the valves
I was talking to one of my buddies and he was sayin that if you run all your valves down a half turn that you will make a lot more power in a way i can belive it but also will it f*** up my head?
Old Jul 4, 2010 | 09:45 PM
RAW's Avatar
RAW
There is a probability that your pistons will hit your valves, and they may stay open all the time without the proper lash. I strongly do not advise that adjustment.
Old Jul 4, 2010 | 10:16 PM
i was thinkin that was a bad idea
Old Jul 7, 2010 | 04:17 PM
thebullet83's Avatar
if you have stiff springs, cam and lifter wear become an issue as well
Old Aug 2, 2010 | 01:54 PM
kerley's Avatar
Default Runnin the valves
98' 24v, How often should the valves be run?
Old Aug 2, 2010 | 04:01 PM
turbo20psi's Avatar
I have done mine at 72,000 but I put some injectors in my truck.I did a truck(2002)
that had 112,000 on it and the valve lash was good.Between 80 to 100,000 a good time to check.Do you know how check for proper valve adjustment.
Old Aug 3, 2010 | 07:28 PM
kerley's Avatar
Turbo 20psi, I inherated the truck with 189k so I don't know about the valves. The owner [my best buddy] was a professional trucker so who knows.
Old Aug 3, 2010 | 08:13 PM
turbo20psi's Avatar
Good time to go ahead and check them,it wont hurt.Some of the guys have adjusted there valves and the truck was more responsive and less noisey.
Detailed site Valve Lash Adjustment
Maybe use full info..2001 ISB engine specs
Old Aug 8, 2010 | 01:29 AM
4 cummins power's Avatar
yeah i have gotta check my valves also but would not run them any tighter than recommended JMO!
Old Aug 13, 2010 | 11:43 PM
voidswarranty's Avatar
it will never hert to run the lash out and just a little tighter and i mean a little will increase dino horse power not enough to to notice set it at factory sepc on the side of the motor unless ur ready to replace long block ive seen them at 35000 out of spec and ive seen them with over 200000 and still be in tollerance every ones differant
what kind of boost are u seeing at 2000 rpm bob tail on the high waty low load
Last edited by voidswarranty; Aug 13, 2010 at 11:43 PM. Reason: Automerged Doublepost
