htt upgrade compressor
Old Jul 4, 2010 | 07:37 PM
thebullet83's Avatar
Default htt upgrade compressor
i'm thinking about getting the upgrade compressor wheel and housing for my truck, the Stage 3.5 so i don't have to get an exhuast housing.
there apparently is some machining required. does anyone know what that might be? i work in a machine shop, so i think i could save that $85 dollars and down time.
i want to do something like this instead of twins so i can still use the turbo-mounted Jake that i have.
thanks
Old Jul 15, 2010 | 08:40 PM
i called today and ordered the 60 wheel and housing. sounds like a simple spin job in the lathe to get the new wheel to fit. while its out, im gonna rebuild the center section.
the manifold might see a little porting too, not sure on that one tho.
Old Jul 16, 2010 | 09:34 PM
Default Re: htt upgrade compressor
Let us know how it performs.
Luke
Sent from my Eris using Tapatalk
Old Jul 17, 2010 | 07:24 AM
tpcdrafting's Avatar
I did the stage 3 kit several years ago. It's a quick job on the lathe. The compressor wheel sits in a depression on the surface of the center section to compressor housing plane. That depression needs widened as the new wheel has a slightly larger diameter. It took longer to get it chucked up on the lathe than to do the widening. I'm not a machinest and I had one of my fab guys do it for me.
As for the upgrade, It did cool things just a bit over stock. I tried it with both the stock 12 cm housing and a 16 cm non w/g. I didn't like the 16 at all at this altitude. With the 12, it spooled very fast and screemed like a banshee on crack!
I've since made the leap into 4" outlet turbo which meant new exh. brake, downpipe, etc. and I'm much happier towing.
Strictly Diesel
Strictly Diesel
Sep 17, 2015 05:11 PM
Air Lift Company
AirLift
11
May 27, 2015 04:38 AM
D-350 dually
9
Feb 11, 2015 12:37 AM
Jan 20, 2015 03:01 AM
carid
Diesel Bombers Sponsors
Dec 4, 2014 05:06 AM
