Tranny Temp
Old Jul 4, 2010 | 04:25 PM
BlackCloud96's Avatar
Default Tranny Temp
What should my cummins run normally not towing just driving, mine is about 180 with lockup vb and converter is that ok and what temp does it start to burn!!!!!!
Old Jul 4, 2010 | 07:00 PM
dan33klein's Avatar
i would recomend getting an auxillary cooler. they come with little ones from the factory that are not made to handle anything more than stock
Old Jul 4, 2010 | 08:31 PM
motorboat's Avatar
Mag Hyteck trans panI The extra fluid makes big difference. I80/190 are my temps when towing heavy.
Just my opinion, your's may of course vary.
Old Jul 4, 2010 | 09:15 PM
dan33klein's Avatar
i personally dont like the bigger pans, sure it gives you more fluid. this will take longer to heat up. but it will take longer to cool down. instead of spending 300 on a new pan. spend 140$ on a nice big tranny cooler that will keep temps under 150* while heavy towing. thats just my .02 cents
Old Jul 4, 2010 | 09:43 PM
sr6000's Avatar
My personal opinion is a larger cooler and deeper pan. That setup has worked great in my street/strip car for more than 8 years, just rebuilt the tranny last year.
Old Jul 4, 2010 | 10:41 PM
DieselJake's Avatar
I have a remote cooler (with fan) mounted under the bed outside of the frame rails. Can't overheat the tranny, it seems. Only reason for a bigger pan, in my case, is to get the drain for changing oil and filter. Well that and to replace the stock pan after somebody stepped on it .
Old Jul 4, 2010 | 10:50 PM
wisconsin redneck's Avatar
i just towed 13k today and mine stayed right around 160 and all i have is a mag tech deep tranny pan.
doodieroot
May 10, 2015 11:48 PM
wilki
Feb 12, 2015 09:04 AM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
emilio2496
8
Jan 13, 2015 05:03 PM
Ol' RED!
Dec 11, 2014 10:00 AM
