1992 Dodge MPG Drop
Old Jul 4, 2010 | 01:10 PM
robinlbird's Avatar
Question 1992 Dodge MPG Drop
I have a 1992 Dodge Cummins and have done no modifications yet. Everything stock.
I watch my fuel mileage closely (reason I bought a 1st Gen) and was getting 19-20 mpg and all of a sudden I am getting 14-15 mpg. Driving miles and speeds are exactly the same. Replaced Air and Fuel Filter with no measurable change.
Any ideas on what to look for first? It doesn't seem to run rough but not sure if this would be a good indicator for clogged injectors or not.
Just turned 130,000 miles on engine. Yes I bought from a little old man that used it once or twice a year with camper shell to Mexico for vacations. Only had 60,000 miles when I bought it in July of 2007. Very fortunate.
Thanks for any help
Old Jul 4, 2010 | 04:58 PM
big bad diesel 416's Avatar
Site Sponsor
how long have you ran it after you changed the filters? The MPG will not come back instantaneously
Brice
Old Jul 4, 2010 | 08:27 PM
TTipsword's Avatar
Brice
deffinatley a fuel issue i think
Old Jul 5, 2010 | 09:12 AM
robinlbird's Avatar
Brice, has been over 6 to 7 months, mpg stays right at 14-15 mpg.
Old Jul 5, 2010 | 09:28 AM
Levi Miller's Avatar
my friends 2nd gen did the same thing butt he bumped the timming 1/16 i think and that helped him
Old Jul 5, 2010 | 10:03 AM
Site Sponsor
dose it smoke excessively? (worse than normal)
In a stock application smoke = restriction either intake (dirty air filter or loss of boost)
or Exhaust (plugged exhaust components)
Do you have a fuel PSI gauge?
Is your lift pump working to capacity?
Have you checked the quality of fuel your getting?
Have you cut open fuel filter to see whats inside?
Have you/do you know of any previous problems with the truck?
Brice
Old Jul 5, 2010 | 10:43 AM
robinlbird's Avatar
Smile MPG Issue
Air Filter is new, I wouldn't know about the boost?, or exhaust. How would I check?
Do you have a fuel PSI gauge? No
Is your lift pump working to capacity? How would I check this?
Have you checked the quality of fuel your getting? Get fuel from different sources so I would assume that is not the issue.
Have you cut open fuel filter to see whats inside? Haven't done that. Changed it twice just to make sure it wasn't that.
Have you/do you know of any previous problems with the truck? First issue with the truck since 2007
Brice
rj
Old Jul 7, 2010 | 01:45 AM
Site Sponsor
GET A BOOST AND EGT GAUGE
No
GET ONE LOL
HIT THE LEVER "LIKE TO PRIME IT" IS IT EASY OR HARD TO PUSH?
OK
OK
OK
Brice
bbilt
5.9L Rotary Performance
May 29, 2015 07:05 PM
shawnecarter
May 11, 2015 02:47 AM
Dec 12, 2014 12:30 PM
Oct 22, 2014 08:10 AM
Oct 10, 2014 08:10 AM
