98.5 tuners
Old Jul 4, 2010 | 08:20 AM
bowtie's Avatar
Default 98.5 tuners
i got a 98.5 cummins and it gets only 14mpg 3.55 gears i have changed all the filters and ran a bottle of kleen it didnt help i was thinking about getting a tuner some say they will get up to 6 more mpg whats the best one to get!
Old Jul 4, 2010 | 08:34 AM
A Programmer or a Box will help for sure. Are you running any gauges? Sounds like you may be running on low fuel pressure this can cause bad mileage, loss of power and will kill an $1000+ VP44 injection pump.
Old Jul 4, 2010 | 08:56 AM
bowtie's Avatar
its got 8-9 lbs at the filter its suppose to have 10 i need to get a lift pump
Old Jul 4, 2010 | 11:15 AM
wyodiesel92's Avatar
Edge jwa and raptor 150
Old Jul 4, 2010 | 12:29 PM
bowtie's Avatar
i just put on a air tex lift pump i will check the mpg now is the air tex any good ? i heard they were a lot better than stock and the truck is all stock!
Old Jul 4, 2010 | 01:21 PM
01cummins13's Avatar
never heard of an air tex lift pump. but you need to make sure it will push enough fuel to support a programmer or box. I have a Bd Diesel lift pump that says it will support up to 600 hp, but cannot meet the fuel requirements of a box or programmer. Air Dog, Fass, and Raptor are the 3 big fuel systems most ppl run. The give you the fuel you need for the box and save you VP44 which as luke stated will cost you 1000 if it goes bad. and thats not something you want to happen.
Old Jul 4, 2010 | 02:54 PM
I ran an Airtex on my 01 with the Vulcan relocation kit. Made 18psi @ idle and stayed right at 10psi with the Edge on Hot. It is a better than stock setup for the money but if your going to do injectors and a box then I would at the least get a Raptor 150 or Fass HPFP 150.
Luke
Old Jul 4, 2010 | 03:19 PM
bowtie's Avatar
i am going to leave it stock ecept for may be a tuner for gas milage i just put the lift pump on today i hope it helps the milage the former owner said it got 20 mpg and i want to get that out of it, its getting 14.5 babying it unloaded but the old pump only had 8-9 lbs at idel i hope it didnt hurt the inj pump!
Old Jul 4, 2010 | 03:26 PM
I would do an Edge Juice with Attitude.
Old Jul 4, 2010 | 03:33 PM
RAW's Avatar
RAW
Heck yeah!! EJWA all the way!!
thatdude38
Aug 31, 2015 05:22 PM
gd1996
For Sale
May 15, 2015 09:42 AM
97boatstroke
Dec 22, 2014 09:54 PM
LawdawgSHPD
Wanted To Buy (WTB) - Used
Dec 6, 2014 06:24 PM
flyers.nhl
Oct 31, 2014 04:33 AM
