drop down pitman arm
Old Jul 3, 2010 | 12:36 PM
Steelheader's Avatar
Default drop down pitman arm
Had a 3" lift done, now I need a drop down pitman arm bad!!!. Can someone tell me where to find one? Everything I try only has '94 and up. My truck is a '92 D250 4X4 1st Gen. 12 valve with a 3" lift. HELP! If need be, get me at rivertomidaho on Yahoo Messenger or srtom56@hotmail.com. Need ASAP---Thanx
Old Jul 3, 2010 | 12:42 PM
tltruckparts's Avatar
just convert it to crossover steering. youll be miles ahead that way
Old Jul 4, 2010 | 11:27 AM
93fatbed's Avatar
Before I went to cross over steering I was running one from sky Jacker, But that was years ago. Don't know if they still make them. Maybe worth calling them if they don't list one on their web site. Good Luck
Old Jul 6, 2010 | 11:08 PM
tower_ofpower's Avatar
summit lists them, you have to look up a lift kit for your application and then go under suggested parts... but be warned drop pitmans can throw steering geometry way out of wack, i did 6" of lift and they sent me the wrong drop arm, the box was labeled for a 4" kit. well i could turn to the right like i was in a little euro compact and turned to the left like a semi or worse. i almost completely solved my problem by buying the spacer for the steering arm that bolts to the knuckle and switching back to the factory pitman arm, i rightfully should take it to a machine shop and have a 1/4 inch shaved off of the block or so to bring everything back to true center w/o buying a $250 adjustable draglink. but the drop arm, will solve bump steer issues but it also changes lateral movement of the drag link. have you driven the truck with the old pitman arm? the block is only like 3.5 inches and i've got 3" of lift on you. if you havent driven it i'd advise you do... wish i did
Old Jul 7, 2010 | 08:20 PM
smokin_93_cummins's Avatar
Skyjacker does still have a drop pitman arm i have one on my truck its for a 4" lift but im sure it will work for a 3" too
Old Jul 8, 2010 | 07:31 AM
NadirPoint's Avatar
My 2" Skyjacker drop pitman has been working great for three years, and it corrected the lift-induced bump steer it had before. Just be advised getting that pitman arm off can be a real bitch. Took a 13-ton puller to separate mine. In retrospect, I'd have been dollars and time ahead if I just took the cutoff wheel to it like I did with the one on the 3rd Gen.
Detroit Tahoe
Oct 5, 2015 05:17 PM
tylerjp34
Sep 16, 2015 03:12 PM
Walker.B
Chevy/GMC Duramax 01-04 LB7
11
Jun 17, 2015 10:40 PM
Detroitpower
Mar 7, 2015 09:31 AM
