Cruise Control not Working? A/C Wont switch off of defrost vents? heres the fix
Old Jul 1, 2010 | 04:23 PM
DB Admin's Avatar
Banned
Default Cruise Control not Working? A/C Wont switch off of defrost vents? heres the fix
this little vacuum line does a lot !! even the 4wd light was not working
Old Jul 1, 2010 | 04:34 PM
thebullet83's Avatar
yup, you break that one, nothing works! that's right off the vacuum pump
Old Jul 1, 2010 | 04:44 PM
dirt diggler's Avatar
That would be a ruff one to find
Old Jul 5, 2010 | 12:24 PM
scottywiest's Avatar
hahah trust me i installed the airdog just like in the pic and i lost my cruise and only the defrost worked soo i went back and traced everything out and finally i opened the hood and it was like a shining light pointing to it!!! i felt like a slapped a@@!!!
Old Jul 5, 2010 | 01:41 PM
tiremann9669's Avatar
Not only the 4wd light, vacum engages the front axle so the 4wd wasn't working
Old Jul 5, 2010 | 01:42 PM
DB Admin's Avatar
Banned
4wd was working , i have to use it everyday
Old Jul 6, 2010 | 03:52 PM
big willy's Avatar
yep one vacuum hose comes off it's like the whole truck wants to go haywire
Old Jul 7, 2010 | 04:56 PM
DavidC's Avatar
Mine rubbed a hole in itself against the trans dipstick tube along the fire wall.
Old Dec 22, 2010 | 10:52 PM
Cummins24valv's Avatar
Default Help-asap snow is coming I need fourwheel drive
Alright well I do have these problems with no fourwheel drive cruise control doesn't work and my heat/a-c is stuck on defrost I found this loose vacuum line that's in the pictures and it's not attached wondering if someone direct me to finding where it's supposed to go thanks any help is appreciated
Old Dec 22, 2010 | 11:40 PM
biged681985's Avatar
there is a vaccumm pump right infront of your powersteering, it will have a rubber gromet on the top of it that that line plugs into
