Transmission Coolers
Old Jul 1, 2010 | 10:07 AM
Rosco's Avatar
Default Transmission Coolers
I think i need an aux trans cooler now. My tranny gets a little hotter than what i like to see when cruisin town and i am wondering what my options were, and looking for ideas on mounting locations.
Old Jul 1, 2010 | 10:12 AM
RAW's Avatar
RAW
I see you have "custom trans" in your Sig, but what is it actually? Auto, Stick, 5/6 speed? That info will help for responses.
Old Jul 1, 2010 | 10:15 AM
NadirPoint's Avatar
Did it always run hot, or is this something new that just started cropping up recently?
Old Jul 1, 2010 | 10:49 AM
turbo20psi's Avatar
What temp is a little "HOT" around town .
Old Jul 1, 2010 | 10:57 AM
Rosco's Avatar
**** sorry its an auto built pretty damn close to a suncoast 3. it gets up around 170. It used to run closer to 140 and i know my smarty aint helpin but i dont wanna take it out.
Old Jul 1, 2010 | 11:03 AM
RAW's Avatar
RAW
I have a stage 2 shift kit, and a triple billet T/C in mine. It runs 170/180 around town or on the hiway, always has since I've owned it. I'm going to remove the heat exchanger on the side of the block and probably change the cooler up front as well. The exchanger is coming out to make room for the S400 that will sit there. I pulled 10,000lbs a while ago and the heat got as high as 220, that too much for me.
Old Jul 1, 2010 | 11:22 AM
Rosco's Avatar
Maybe im ok then. I was pullin elven thousand a while back and saw 150 but that was between Gillette Wyomin and Pueblo Colorado. Maybe im worried over nothin.
Old Jul 1, 2010 | 11:33 AM
NadirPoint's Avatar
That would be my opinion. 170 is nothing. ATF+4 is rated for over 300 continuous. Not that you'd want to be running on the hairy edge like that or anything, but 170 is nothing.
Old Jul 1, 2010 | 12:03 PM
01quadcab's Avatar
bypass your heat exchanger and have your front cooler cleaned out or get something better for it.
Old Jul 1, 2010 | 12:31 PM
NadirPoint's Avatar
Originally Posted by 01quadcab
bypass your heat exchanger ....
You really think that's good advice for somebody living in CO and evidently hauls even further north?
