47RE Valve body removal?
Old Jul 1, 2010 | 07:53 AM
woodly1069's Avatar
Default 47RE Valve body removal?
I know this is going to sound stupid but yesterday I went to make some "improvements" in the old tranny's valve body and had a real problem getting it out! I've always had Chevy's and Ford's and their transmissions are almost carbon copies of each other; this Dodge is VERY different! I did something stupid and made an assumption that it would be like all the other makes. Anyway, I am looking for some instruction on how to get this thing apart correctly that's all. I just don't understand how it should be done without such a hassle! Any insight would be greatly appreciated as I can't find a transmission book in this city!
Old Jul 1, 2010 | 10:12 PM
cumminspwr11's Avatar
humm, y are you tryin to take the whole valve body apart? i havent taken one apart yet but i have pulled them out and the real pain is putting it back in
Old Jul 2, 2010 | 08:09 AM
woodly1069's Avatar
Don't tell me that! I have to put it back in tonight! I think I have it figured out though, seems that I have to move the gear selector enough to reach the dreaded E-clip then I should be OK! Wish me luck!
Old Jul 2, 2010 | 11:44 AM
you might have to unbolt the drive shaft from the rear end and get a friend to turn it side to side (only a little bit) so that you can get that arm or shaft back in right, sometimes their a bitch other times there easy, there is a linkage arm thing back by the od unit that the shaft pushes on and thats what you have to get in the right place
Old Jul 2, 2010 | 12:05 PM
woodly1069's Avatar
good thought! Thanks!
Old Jun 20, 2011 | 10:28 PM
$2800 12valve's Avatar
i just dropped my valvebody bout 3 hrs ago just enough to take the od solenoid out and it was still a pain and now my trans issue is worse!!!!!!! i didnt have od now its all chuggin in low speeds
RA113024
Mar 13, 2016 07:42 PM
South Tx Coal Roller
Nov 15, 2015 10:24 PM
jeremiah1
Jul 21, 2015 06:35 PM
jeremiah1
Jul 17, 2015 09:06 AM
Bigredpowerstroke
Feb 3, 2015 05:48 PM
