gas pedal
Old Jun 30, 2010 | 04:16 PM
alejandro70's Avatar
Default gas pedal
i have a 1995 dodge cummins and last night all of a sudden my gad pedal got real loose and it hauls *** now if i barley push the gas pedal....could it be a broke govenor spring or what?
Old Jun 30, 2010 | 04:27 PM
94 12valve's Avatar
could be a return spring came off or broke
Old Jun 30, 2010 | 06:39 PM
Will it mess up the truck if i drive it like this for a while?
Old Jun 30, 2010 | 07:06 PM
cumminspwr11's Avatar
sounds like the return spring, i drove mine forever without one just makes it really touchy to drive and easier to stall
Old Jun 30, 2010 | 07:08 PM
tltruckparts's Avatar
i would at least check it out. all you gotta do is look for a spring on your throttle linkage returning it to the idle position
Old Jun 30, 2010 | 09:21 PM
94 12valve's Avatar
you should check and see if it was a return spring ... IMO I would reinstall it if that was the problem.
Old Jun 30, 2010 | 09:47 PM
Pyro690's Avatar
Gas pedal? Would bet its just the return spring on the throttle arm. Best to look and check it out. Maybe stretched out.
Old Jul 1, 2010 | 04:46 AM
FastCR's Avatar
x5, the 12v throttle setup is pretty simple. sounds like you've partially lost the spring that brings the linkage back to idle. The throttle cable is pretty much setup the same as a gasser AFAIK, just hooks to the side of the p pump.
However, it's a diesel. that is now the "accelerator" pedal. not the gas pedal.
weatherby
Aug 31, 2015 08:04 PM
Moly Squid
Mar 28, 2015 04:26 PM
Jan 28, 2015 12:10 PM
krinderhagen
Dec 31, 2014 07:12 PM
Dec 16, 2014 05:40 PM
