No 4Wheel drive??
Old Jun 30, 2010 | 02:11 PM
Sudia247's Avatar
Default No 4Wheel drive??
Hey everyone,
When I put my truck into 4HI it sounds as if the shifter wants to pop out, and when I put the truck into 4LO, You can hear gears grindin for a little and then it pops out of gear. I was told it would be an easy fix but I don't know exactly what I need to fix. If this sounds familiar to anyone can you help me out and let me know whats wrong?
Thanks so much,
Aaron
Old Jun 30, 2010 | 09:19 PM
94 12valve's Avatar
there is an adjustment on the bottom of the shifter, its right by the t case. Should be a arm with a screw. I'll try and get a pic tomorrow
Old Jun 30, 2010 | 11:26 PM
Sudia247's Avatar
ok, thank you, it does go into gear, just when i step on the gas it does what i explained above in my first post.
Old Jul 1, 2010 | 04:53 AM
94 12valve's Avatar
if its not this adjustment, Its prob your shift fork in the t case. There made with some plastic parts that tend to brake off
Old Jul 1, 2010 | 06:57 AM
Billy D's Avatar
Nice mo plastic
Old Jul 5, 2010 | 12:21 PM
lil red's Avatar
sometimes the snap ring on rear out put shaft breaks and causes similar cond. pretty easy fix also
Old Jul 6, 2010 | 03:23 PM
big willy's Avatar
there is a way to check if it is your transfer case very easily because mine did the same thing and it's something inside my t case what you need to do is get on a hill that you can back down but can't go up in 2 wheel drive and get someone to look up under the truck at your front drive shaft if that's spinning it's your axle internals if it isn't it's inside your t case.. hopefully that will help you
Old Jul 13, 2010 | 04:19 PM
Sudia247's Avatar
I dropped my Tanny and TC last night and took some pics of the linkage. I'm not sure what the linkage is supposed to look like but if anyone has an opinion on if the linkage can be causing my 4 wheel drive not to work properly I'd like to hear it.
Thanks,
Aaron
Old Jul 14, 2010 | 08:05 AM
lil red's Avatar
That all looks as it should Inspect rear of t-case where rear prop shaft slides into remove four bolts for rear support housing remove housing and see if there is a snap ring still on shaft at the bearing preventing shaft movement forward this was a common failure on earlier t-case's if its not broken then I would suspect worn fork's and or plastic fork "wear" insert's hope this helps.
Old Jul 19, 2010 | 03:55 AM
Sudia247's Avatar
Thanks! I took apart my Tcase today and you were right. my snap rings were broken and the plastic parts on the shifting fork were broken. You were right on. thanks again!
May 28, 2015 02:10 PM
Mar 19, 2015 08:10 AM
6.5dieselman
Feb 26, 2015 04:45 PM
Feb 17, 2015 11:50 AM
MAC4232
Jan 28, 2015 01:46 PM
