timing trouble?
Old Jun 30, 2010 | 09:35 AM
01rampower's Avatar
Question timing trouble?
I have an 01 cummins that I have completely rebuilt. I am having trouble with timing, I think. When it gets to operating temp, it runs rough and blows white smoke at an idle. It also will do the same thing when accelerating slowly from 750-1100rpms. I have edge 150 inj, cfm elbow, stage 1 intake, edge drag comp, new ecm, new inj pump, and basically all new sensors. The setting on the drag comp makes no difference in the problem I'm having, and it gets worse if i turn it off. It also has a hard start problem on the first start of the day. I have not replaced the pcm or the throttle position sensor. I am running out of ideas and funds. Does anybody have any ideas that might help solve this problem? Thanks in advance.
Old Jun 30, 2010 | 10:40 AM
dodge rodder's Avatar
white smoke could be weak turbo or over fueling. I worked on a ford 6.9 that the turbo was jacked up on and it did that. thats all i know
Old Jun 30, 2010 | 10:42 AM
kmkdiesel's Avatar
sounds like it might be an injector issue
Old Jun 30, 2010 | 11:23 AM
00CumminsMan's Avatar
It sounds like timing lik you said, but it also sounds lik injector issue to. thats my opion.
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
jjbced
Oct 26, 2014 09:09 PM
