93 cummins
Old Jun 29, 2010 | 11:31 PM
HAYMAFIA's Avatar
Default 93 cummins
i screwed the smoke screw in and now the when you rev the truck it takes a long time for it to return to idle. checked all linkage it returns as soon as you let off but the revs stay high and idle down slowly. whats wrong with it
Old Jun 29, 2010 | 11:36 PM
Budgreen's Avatar
sounds like it's on the verge of runaway!
Old Jun 29, 2010 | 11:38 PM
tltruckparts's Avatar
the smoke screw shouldnt do that thats a full power screw related problem.
Old Jun 29, 2010 | 11:41 PM
HAYMAFIA's Avatar
ok im a p-pump guy. its the one with an inch long tin cap that you have to break off and use a 13 mm wrench and a 6mm wrench to adjust.
Old Jun 29, 2010 | 11:44 PM
ya thats the smoke screw, on top of the afc right?
Old Jun 30, 2010 | 12:02 AM
HAYMAFIA's Avatar
no its towards the rear of the engine on the pump. right above the injector lines at the pump.
i looked at some pics and it is the full power screw. do i need to screw it out some?
Old Jun 30, 2010 | 01:27 AM
TTipsword's Avatar
ya you dont want it that high.....turn down ASAP or have a runaway
Old Jun 30, 2010 | 07:30 AM
Budgreen's Avatar
yes! turn it back until throttle control is back to normal
unless you wanna hear a cummins rev to 8k and hold till parts forcibly leave the block
Old Jun 30, 2010 | 09:43 PM
HAYMAFIA's Avatar
got it under control. but it sure smoked more with it on the edge of runaway. can i put 215 injectors in this engine? how much would it help
Old Jun 30, 2010 | 09:50 PM
big bad diesel 416's Avatar
Site Sponsor
the VE is only good for so much HP
but not for long
