front end ?s
Old Jun 29, 2010 | 07:47 PM
casper83's Avatar
Default front end ?s
im having to replce my ball joints in my 96 ram 3500 4x4. what size is the nut on the inside of the hub to take it off the axle. is there any other special things i should know before starting this project?
Old Jun 29, 2010 | 09:32 PM
lunk's Avatar
look up the socket trick to get your hub un stuck from the knuckle, also for size i cant remember but its a 12 point socket not a six on some of them hope this helps a little
im soory wrong thing its a 33mm i believe
Old Jun 30, 2010 | 06:17 AM
oldgrey90's Avatar
i think the axle nut is 1 11/16 and the bolts that hold the bearing in are 14mm 12point
Old Jun 30, 2010 | 09:48 PM
dan33klein's Avatar
definatly NOT a 33. i tried a 36 and it was to small. id go with the last post, i believe its the right one. i did mine two weeks ago. i found it easy to take the four bolts out the back, and put in a longer one and beat the hub off. or if your doting brakes and rotors to like i did, take out the bolts and beat the rotor with a sledge and it will come out
Old Jul 8, 2010 | 10:02 AM
Johnny Z's Avatar
X2 on what Dan is saying, but try this. When u put the longer bolt in, if you can safely start the truck...I use a lift on my truck, turn the steering wheel and use the hydraulics to push the hub off. Works like a champ and no beating ****.
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
