Tranny problem
Old Jun 29, 2010 | 05:33 PM
botjeff's Avatar
Default Tranny problem
I have a 96 dodge with a 5.9 and 47re tranny . when it shifts from 2nd to 3rd it goes into 3rd then kicks back in to 2nd it seem that it doesnt know what gear it should be in . Any one got an idea to fix this?
Old Jun 29, 2010 | 05:46 PM
00CumminsMan's Avatar
It sounds lik torqe converter. I'd start savin for a new trans. You got any mod's done to it?
Old Jul 1, 2010 | 03:50 PM
botjeff's Avatar
no mods yet
Old Jul 1, 2010 | 04:16 PM
glfredrick's Avatar
I'm not sure that the torque converter would be the problem. It doesn't care which gear you are in -- it just transmits engine power to the front pump by liquid or lock-up clutch means.
I would be inclined to look at the valve body, band, or linkage adjustments instead.
Have you regularly changed fluid and filter? There is a shuttle valve in the 2-3 position that might either be locked in its bore from dirty oil or have a broken spring, requiring valve body repairs. The good news is that valve body repairs do not necessitate removing the transmission from the truck.
The 2nd gear band may also be the culprit. Bands are to be adjusted ever 24,000 miles, but this seldom happens. Geno's Garage says this:
The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
Here is the link to the article:
94+ Ram AT band adjustment
Old Jul 5, 2010 | 12:17 PM
lil red's Avatar
I think I might also verify proper kickdown cable adjustment too tight and it will tend to "hunt" up and down
Old Jul 6, 2010 | 03:16 PM
big willy's Avatar
does your tranny do this between say 40 to 55 mph?
Old Jul 6, 2010 | 04:08 PM
lil red's Avatar
Mine is actualy an H series but I have had many cust. with same cond. at 40 to 55 try loosening cable abit release catch and push cable housing towards throttle belcrank connection. throttling pressure overrides gov. press. and this will increase pedal travel required for downshift will also affect upshift points hope this helps
Old Jul 6, 2010 | 04:18 PM
botjeff's Avatar
Default tranny problem
it only does it when u step on it from a stop. If just go easy it dont do it.
Old Jul 6, 2010 | 06:00 PM
BlackCloud96's Avatar
mine did that also my tranny was junk what does the fluid look like black or smell burnt if so start saving for a good tranny
Old Jul 7, 2010 | 09:15 PM
guldam's Avatar
My 97 4x4 auto makes a whirring, rubbing sort of noise when towing my boat up some pretty steep hills. Truck has overdrive off. It makes the noise when it transitions from 2nd to 3rd. I'm trying to sell my Aprilia Falco so I can get a new tranny. hrrrrmph!
Steveoh
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
tim12valve
9
Apr 21, 2015 05:51 PM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
