Twin help
Old Jun 29, 2010 | 04:55 PM
00CumminsMan's Avatar
Default Twin help
Need some advice for buildin the baddest street twins. Any advice for me? And as anybody ever drop a valve and destroyed there motor? Her is a pic of my bottom end[ATTACH][/ATTACH]
Old Jun 29, 2010 | 06:10 PM
Anybody got any idear's?
Old Jun 29, 2010 | 06:29 PM
RAW's Avatar
RAW
I've ridden in a few trucks running HX35 and S400 COMPOUND turbo set ups. They pull pretty hard, and can be budget friendly. I am going to build the same thing for my truck.
Old Jun 29, 2010 | 06:48 PM
01quadcab's Avatar
how bad do you want to go? my s300/475 combo is making 665. The injectors I am running now are not very street friendly. But it was making 602 and not nearly as much smoke. The valve seat is usually a problem on hardened seat heads like 02 and up. Seen 2 personally do it. Depending on how far you want to go you will also need trans mods, head studs, o-rings, springs and retainers. If I had the money I would be doing some injectors changes to find the best street friendly set that makes the most power. But my budget went down the tubes with slow work and 2 surgeries coming up.
Old Jun 29, 2010 | 08:48 PM
turbo20psi's Avatar
Got a little hot,to much timing.
Old Jun 29, 2010 | 09:59 PM
Am shootin run 12's when i get my motor back from the shop. I have studs and o-rings done to.What size injectors you running and injection pump you running? How much would that s300/475 combo cost, just turbo's?
You know any body sellin a s400 turbo?
Last edited by 00CumminsMan; Jun 29, 2010 at 09:59 PM. Reason: Automerged Doublepost
Old Jun 29, 2010 | 10:00 PM
RAW's Avatar
RAW
Can't say that I do at this time.
Old Jun 29, 2010 | 10:10 PM
thanks anyway.
Old Jun 29, 2010 | 11:31 PM
01quadcab's Avatar
post up in the vendor section my current injectors are not know exact size to me. local shop put them in. but if you want to run 12's get a s300 and a set of 150hp ddp or mach injectors and you are there for a lot less money than compounds and it will drive and tow fine. SOvp is what I am running with a drag comp. Looking to hit 700hp fuel only pretty soon.
Old Jun 29, 2010 | 11:37 PM
I have 150hp nozzel's in now. Would my hx35 and s300 be good idea?
