Starter has worn out....
Old Jun 28, 2010 | 04:09 AM
angelic0-'s Avatar
Default Starter has worn out....
beating on it with a hammer got it started once... now it's completely dead...
is this common ? how much is a replacement unit and how hard is the replacement ?
Old Jun 28, 2010 | 05:51 AM
94 12valve's Avatar
sounds like your contacts are bad, Larry B's kit will fix it. Cheep and an easy install
Old Jun 28, 2010 | 06:13 AM
angelic0-'s Avatar
you think the starter is still ok ?
Old Jun 28, 2010 | 08:08 AM
glfredrick's Avatar
Depending on how hard you hit it with the hammer, the starter itself can be fine. Usually the contacts wear out.
Replacements are often a dissapointment.
Larry B's has already been mentioned. Check them out:
LarryB's Dodge starting problems solved here.
Old Jun 28, 2010 | 10:19 PM
85_305's Avatar
Being Evaluated
I can pretty much guarantee the starter is fine. These things are a hoss. The things that do go bad are the contacts. Get the larry b heavy-duty contacts and be done with it. DONT get the brushes unless you HAVE to. They are tough tough tough to weld in.
Old Jun 29, 2010 | 02:48 AM
m1ashooter's Avatar
I just did this very fix a couple weeks ago, 24 bucks for the contacts, and took me 40 mins total time. Very simple easy fix...
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
thunderball52
Oct 6, 2014 08:08 PM
