whats wrong here???
Old Jun 27, 2010 | 05:18 PM
rollincoal12valve's Avatar
Default whats wrong here???
i ordered a phatshaft 62/65/14 to replace my blown up hybrid and changed nothing else and i am seeing egts that are 300 degrees higher than with my hybrid
i figured there shouldnt be any heat at all with this turbo compared to my other one but i cant even go wide open for more than 10 seconds before i hit 1300 degrees....
its making the correct 40lbs of boost so i cant figure out whats wrong?
Old Jun 27, 2010 | 06:09 PM
tltruckparts's Avatar
thats odd. my hx40 would topple over the 1600 mark and my phatshaft wont hit over about 1300 or 1350 now.
Old Jun 27, 2010 | 06:44 PM
jrad989's Avatar
thats really odd. how fast can you spool it?
Old Jun 27, 2010 | 07:54 PM
pretty fast like 10 seconds it will go from 0lbs to 40lbs when it first shifts into overdrive and you put er to the floor... other than that i love the thing i just dont want it to blow my **** up do you think my homeade intake is holding it back? the filter is almost a year old and is paper should i invest in say a s&b intake?
Old Jun 28, 2010 | 12:18 AM
jrad989's Avatar
i dont think its holding it back. whats your homeade one look like?
Old Jun 28, 2010 | 05:52 AM
94 12valve's Avatar
what boost were you making with the 35/40?
Old Jun 28, 2010 | 05:52 PM
its a big filter from napa and the stock intake tube
and i was makin about 43 peak and about 38 when it leveled off
this cant be right i have stock injectors i couldnt imagine what bigger ones would be like
think it would be smart to throw in a set of 3ks that i have?
Old Jun 28, 2010 | 08:37 PM
94 12valve's Avatar
after the charger lights what are your egt's vs the 35/40?
what rpm does the new charger light?
Old Jun 29, 2010 | 02:30 PM
cumminspwr11's Avatar
ok not tryin to sell the post but with my hx40 with a 14cm housing i cant push it over 1000* with all the fuel im running, it stays around 30psi of boost and the probe is right after the turbo, how come all you guys are so much higher? is it cause of my probe location?
Old Jun 29, 2010 | 02:36 PM
biged681985's Avatar
because there is about a 300 degree drop from pre turbo, to post turbo were u have urs
