no start or crank?
Old Jun 26, 2010 | 10:40 PM
wyodiesel92's Avatar
Default no start or crank?
Today I went to start my truck after driving a short distance and I had to cycle the key twice to get it to crank, what would the problem be? It was like no crank the first two turns so I turned it off and back on and waited for the light again and it started first crank. Could it be that the temp was below 60 degrees? Its done it before but normally only in cold weather.
Old Jun 27, 2010 | 11:33 AM
turbo20psi's Avatar
Lift pump is getting air in the line.Stock lift pump?
Old Jun 27, 2010 | 11:36 AM
RAW's Avatar
RAW
I'm thinking start circuit intermittent problem. Like a relay or perhaps the starter solenoid itself. Especially with the no crank part of the no start situation.
Old Jun 27, 2010 | 01:17 PM
J-Pipes's Avatar
Could just be the contacts in the starter, had to replace mine about 2 weeks ago
Old Jun 27, 2010 | 02:42 PM
Yes stock lift pump, being replaced soon hopefully with a raptor.
And I was thinking it was something with the starter too, ill check it out soon if it gets worse
Old Jun 27, 2010 | 06:09 PM
turbo20psi's Avatar
Old Jun 27, 2010 | 09:51 PM
Thanks for the links!
Old Jun 28, 2010 | 03:49 AM
turbo20psi's Avatar
Old Jun 28, 2010 | 08:25 AM
24vcumminscowboy's Avatar
if youve got a manual it could be the clutch switch i know mines going out
Old Jun 28, 2010 | 10:22 AM
Hmmm this could be more work then I intended haha. Its hard to do something and know it solved the problem because it hardly happens, but when is does all I can do is curse and hope it'll start. Its happened maybe 3 times since I bought it, it did it the first two times within the same month but it hasn't for a few months and did it the other day. Atleast the clutch fix can be done for nearly free, the stater one is still cheap though.
