Weird
Old Jun 26, 2010 | 10:23 AM
churkeepwrstrke's Avatar
Default Weird
my 05 f-350 makes this wierd noise whenever i hit a bump. its like a clanging noise like something is loose. the truck drives fine. ive check out the front end and from what i can tell everything seems fine. someone said it could be the ball joints maybe? if so what how much would i be looking at to get them replaced? any ideas?
Old Jun 26, 2010 | 01:12 PM
rkadcock's Avatar
N.M. Bombers Director
is it in the front end? check your exhaust, me and my buddies 6.0s both lost a factory bracket with the stock exhaust and our exhausts were backing around whenever we'd hit a bump or something
Old Jun 26, 2010 | 03:35 PM
BLACK_06POWERSTROKE's Avatar
ball joints on these trucks can get into your pockets pretty hard.. id take it to someone trustworthy and have them look at it.. before i just went "throwing" parts at it
Old Jun 26, 2010 | 06:30 PM
Karls03's Avatar
Ball joints: with a jack stand under the axle, grasp tire at 12 and 6 positions, push with one hand while pulling with the other a few times. If you feel excessive movement, you're a winner of some new balljoints.
Is it lifted and/or has the track rod or it's bracket been removed from the frame? I went through this when I lifted mine, had to re-torque the upper track-rod and the drop bracket. If that sucker comes loose again and I'm welding it to the frame!
Old Jun 26, 2010 | 07:40 PM
thanks for the response. yea its in the front end. ill have to check it all tommorow when i get off work. its not lifted but i do have larger tires on it. it has 18 inch wheels. would it make any diffierence if i put 17s on it? ive been thinking about it and wheels and tires would be cheaper.
Old Jun 27, 2010 | 07:44 AM
papachuck's Avatar
check your swaybar bushings, they make alot of noise when they go bad.
Old Jun 29, 2010 | 08:33 PM
ive checked everything not sure what im looking for in when checking the bushings. im not a mechanic by any means. but theres nothing loose, jacked up the whole front end. i cant find anything. guess it will just have to go to the shop. thanks for all the help!!!
Old Jun 30, 2010 | 01:29 PM
Karls03's Avatar
Before you completely give in, this is how I found my loose track rod mount: have someone watch the suspension while turning the wheel from lock to lock. My buddy saw the bracket slopping around. Can't hurt.
Old Jul 4, 2010 | 08:05 PM
i was checking out PSN earlier a guy with similar issues said to change my front hubs. how labor intensive is this? he said it took about 20 minutes so im guessing i may be able to do this myself??
Old Jul 5, 2010 | 04:23 PM
Mdub707's Avatar
The auto hubs are ridiculously expensive, but I dont believe they're hard to change.
