cummins overflow valve
hello to all my cummins lost fuel pressure so i checked overflow valve and spring was broke in it and ive tried all parts stores around where i live and dodge places and they cant get me one i was wonderin if i could get another spring and put in it i have to be back at work monday and this is my only welding truck.thanks
ok thanks ill definately do that its just got to last a couple days. thanks
do i need one thats the same big around as in spring size
Last edited by aaronmoore; Jun 26, 2010 at 10:50 AM. Reason: Automerged Doublepost
just get the cheap pen that most people give away, most are black and white or blue and white, you have to perty much put the spring into a coil bind, so when cutting it make it bigger than you know it will ned to be and then trip it down until you can reassemble the valve. it'll hold enough that way. if you cut it too short then the fuel will just flow right past it.
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
PeteBug
Jun 11, 2015 12:16 PM
river rat
May 18, 2015 05:04 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
