rebuilt 48re NO GO!
Old Jun 26, 2010 | 12:29 PM
dangerous1965's Avatar
Default rebuilt 48re NO GO!
OK so rebuilt the trans and put one of those GM upgrade pressure soleniods in and have a few problems!
CODES: 1757 Gov pressure above 3psi in gear at 0mph
1762 Gov pressure sensor offset volts to low or high
The truck will not shift out of 1st untill I let off the throttle AND rpm's drop to below 1200.
Very bumbed right now I think I did everything right any ideas out there! After it shifts out of 1st it then goes thru the gears normally! BUT getting it there is the problem I know I can do 30mph in first at 3500rpm!
UPDATE:::: Though I didn't want to drop the pan again I did and changed out the Gov pressure sensor and................ That fixed it! SO the moral of this post is even if it's new doesn't mean it's good! Amazing what a bad sensor will do! I still want that constant pressure valve body from Dave!
Last edited by dangerous1965; Jun 26, 2010 at 12:29 PM. Reason: Automerged Doublepost
Old Jun 27, 2010 | 01:07 PM
GhostRider3149's Avatar
You've been quiet....now i see what you been up to andy
Old Jun 27, 2010 | 06:03 PM
Oh yeah now if I could get this NOS system figured out! Anybody got some tuning tips?? Nozzle sizes Etc........
Kfohne21
10
May 12, 2022 10:13 AM
JJ Diesel
Sep 14, 2015 02:38 AM
jeremiah1
Jul 21, 2015 06:35 PM
Jgloveracob
Wanted To Buy (WTB) - Used
Apr 18, 2015 04:19 AM
Max713
Apr 17, 2015 05:41 PM
