Check Gauges?
Old Jun 25, 2010 | 10:24 PM
big wally's Avatar
Question Check Gauges?
Have an 02 5speed 2wd.
CHIME, "Check Gauges", comes up on the dash.
Zero Voltage, showing. Nothing dead flat.
Stop.
Shut her down.
Check under the hood,nothing unusual.
Start her up, voltage is fine, she is charging.
This happened about 2 weeks ago, has run fine, then today, she does it again.
Shut her down, restart, all is fine,
What could it be, PCM (voltage regulator is in there) (OUCH), alternator or could it be a splice in the factory harness, I have heard of some problems in some of the factory soldered joints.
Other than that she runs great.
Will check for codes on monday.
Thanks in advance.
Have a great weekend.
Old Jun 25, 2010 | 10:46 PM
J-Pipes's Avatar
Try giving this guy a call, mine was doing the opposite and overcharging, and I got a kit for the altenator from him for around $40 I think, just give him call and tell him what it's doing. Ken McCabe, 1-740-342-5007. Been about 2 weeks since I put it in and haven't been having the problems anymore.
Old Jun 26, 2010 | 08:12 PM
turbo20psi's Avatar
If it the voltage regulator they do sell external ones .If you need a alternator rebuild kit GOULD GEAR AND ELECTRIC INC. very easy to do and you will save money.Any code?
Old Jun 29, 2010 | 09:45 PM
big wally's Avatar
Default Gauges
Thanks for the input.
Looks like it was, looking at the engine from the front, the positive battery cable end, drivers side.
It was the small red cable. It looks like either it was never put together corrrectly or it just worked itself loose.
Replaced the cable end with an inexpensive bolt on universal.
Will have one made up asap.
Going for a long drive, Calgary, Portland, next week.
Will let you know, if anything goes wrong.
Thanks again
flainn
Oct 12, 2024 09:39 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
May 1, 2015 08:10 AM
moneypitk5
Feb 12, 2015 11:01 AM
