Help
Old Jun 25, 2010 | 07:43 PM
pngmotoman's Avatar
Question Help
Ok so doing the manual swap in my truck and can't figure out the netrual saftey switch stuff. Where is the wires I need to run power to and how did you guys do it?? Also I have heard plenty of times I can use my smarty to program my truck for manual but can't find the info on how that is done? Anyone know how to?
Old Jun 25, 2010 | 09:02 PM
dangerous1965's Avatar
Just to be clear your going from auto to manual? If so did you get a wrecked truck to scavage from? The tranny has a control module with wiring harness that can be swapped with the auto unit. BTW Are you selling the auto? I'm interested!
Old Jun 25, 2010 | 09:16 PM
pngmotoman's Avatar
Ok the only wiring I have for the manual is the one plug unless it is what goes into the clutch pedel switch one. And yes I have the auto but it is fried bad I'm going to try to get suncoast to fix it then it will be good but I do have two good converters one is bd and the other is dtt
Old Jun 25, 2010 | 10:22 PM
Yeah there's a couple one at the pedal one at the trans neutral switch and I think that's it! Is it a suntoast tranny? They don't warranty even when it's thier fault! Your not to far from me! I'm in San Diego!
Old Jun 25, 2010 | 10:44 PM
pngmotoman's Avatar
Yah it is a suncoast. ok well I will take a look at the wiring for the old truck and see what the wiring looks like but my parts truck is a 05 and mine is a 06 so the wiring is a little diffrent because I was thinking of just swapping the hole wire harness but there is some stuff that won't match up
Old Jun 25, 2010 | 10:53 PM
Hmm pretty sure they are the same! What are the build dates? Only thing different is the tranny controls. Keep me posted on the trans I'm having my own issues right now!
Old Jun 26, 2010 | 04:55 PM
pngmotoman's Avatar
Ok sure will the truck is at a friends house so I'll get the build ate in the morning
My truck is 9-05 and the parts truck 11-04
Last edited by pngmotoman; Jun 26, 2010 at 04:55 PM. Reason: Automerged Doublepost
