twins
Old Jun 24, 2010 | 08:34 PM
24vcumminscowboy's Avatar
Default twins
hey guys im thinkin about putting twins on my pickup and was wandering if there was a kit or something i want to keep my hx35 and just get a s300 with it i dont know much about twins i know would need head studs and im not lookin for anything xtreme just for towing and daily driving any info appreciate it thanks for readin
Old Jun 24, 2010 | 09:10 PM
RAW's Avatar
RAW
A few companies make kits that utilize your factory top turbo. I am currently fabbing up a setup that will use a S400 and my HX35. I have a hotpipe that will bolt to the S400, but has a S300 flange on it. Fortunately I have found an adapter to connect HX35 to HX40 flange. I have been reassured S300 s and HX40s have the same flange. It's tough to get just the hotpipe from companies, they know what your up to and don't want to loose a sale.
Old Jun 24, 2010 | 09:46 PM
is the s400 better or should i just look for a s300?
i just found this kit PDR Diesel Performance: Cobra Stage 1 Twin Turbo Kit (HX35/HT3B) 1998-2002 Dodge Cummins
Last edited by 24vcumminscowboy; Jun 24, 2010 at 09:46 PM. Reason: Automerged Doublepost
Old Jun 24, 2010 | 10:04 PM
RAW's Avatar
RAW
The kits look great, I do agree. I just can't bring myself to spend that kind of cash on something I can make myself for much, much less. Especially as I acquired my S400 for $0.
I have heard opinions that a S400 is "lazy" for a set of compound turbos. Yet I have ridden in 3 trucks using S400s, 1 that still uses the factory HX35 as the top turbo, and they pull HARD.
Old Jun 25, 2010 | 11:11 AM
ya no kiddin have u heard much about those ht3b turbos the kit im lookin at uses ur hx35 on top and the ht3b on bottom
Old Jun 28, 2010 | 01:58 PM
sstockton's Avatar
If you are going to run an s300, you want an s366. And in all honesty, you will save money by running a larger primary. The s400 and ht3b are both very good options for a set of all around street/towing twins on a budget. Both turbos are readily available, and are usually quite a bit cheaper than the modified s300 variants out there. Parts and kits are also readily available as well. The s400 would probably spool a bit faster than the ht3b, but both are decent chargers.
Sending you a PM to go along with this post as well.
Sean
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
