new turbo and still high egts?!?!
Old Jun 24, 2010 | 12:45 AM
cummins4liffe's Avatar
Default new turbo and still high egts?!?!
so i just put in my new turbo its a bd super b SPECIAL and im still seeing high egts up to 1550 degrees WOT peak boost is 40 PSI any advice
MODS-super b special, edge with attitude hot unlock, 125 horse injectors, airgog 150, moto metal 959 black wrapped in 35s
Old Jun 24, 2010 | 02:48 AM
bobcat67's Avatar
new turbo doesn't always mean lower egts, when i got my new one my egts still run about the same as they did before, i just know that now my turbo can handle the egts a bit better, I'd say maybe you need to look else where, intercooler should help a little bit, what are you running for exhaust? maybe look into a water meth set up cause it's really good at calming down the egts, big injectors aren't helping the cause much, of course i don't know how big 125's really are on a VP44 truck, that's a big injector on a common rail i know that
Old Jun 24, 2010 | 06:51 AM
12vcummins96's Avatar
x2 turbo will help maintain the egts and harness the power of all that fuel i would definetly look into a water/meth setup it will drop your egts up to 300 degrees also turn down your edge to number 5 that will help as well
Old Jun 24, 2010 | 09:06 AM
01quadcab's Avatar
Your probably lacking some on the fuel for that charger. What sticks are you running?
Old Jun 24, 2010 | 11:33 PM
got full 4 inch mbrp straight pipe and stage 4 injectors
i was lookin at water meth myself and will most likely order it after head studs go in
Old Jun 24, 2010 | 11:48 PM
01quadcab's Avatar
what brand injectors?
Old Jun 24, 2010 | 11:54 PM
mainman300's Avatar
a manifold will help alot
Old Jun 25, 2010 | 12:00 AM
01quadcab's Avatar
pairing the injectors to the turbo will work wonders. I ran my 62/71/14 with ddp 110's and a stock manifold and never saw over 1400 down the track.
Old Jun 25, 2010 | 12:49 PM
there bd pulse stage 4 injectors
would water meth help spool that monster a little faster also?
Old Jun 25, 2010 | 10:49 PM
LawnScum's Avatar
i ran 150s with my special with smarty and quad adr stack and i never had a problem with egts besides toweing. idk if your up for it but a port and polished head with a 181/210 cam from hamilton did wonders for my truck. power band is awsome and i have to try very hard to get egts over 1000
