03 smoking like a tar kettle
Old Jun 23, 2010 | 03:24 PM
94dizzyram's Avatar
Default 03 smoking like a tar kettle
Hey, guys. My boss mans 03 is acting up. We just changed the fuel filters hoping that would help but it didnt. When it gets up to normal temp and you go to pull a hill it starts to cut out and smoke. I have seen this before on a truck that the egr went bad on. Does that sound like it could be a possible cause and if so could we just delete it with a egr delete kit.
Thanks for the help, Heath
Old Jun 23, 2010 | 05:19 PM
Mdub707's Avatar
Yes it's a possibility. Also possible that the turbo vanes are sticking. Is there any codes? What year is the truck? Any mods on it now? You can take the EGR valve out and take a look at it. If it's gunked up and sticking, you can clean it really well and retry it to see if it helps.
Old Jun 23, 2010 | 05:33 PM
94dizzyram's Avatar
The truck is a 03. It has no mods and I havent checked the codes. He has it at the stealership now. I guess we will see what they say. If it is the egr though can he delete it and it be ok.
Old Jun 23, 2010 | 06:49 PM
BLACK_06POWERSTROKE's Avatar
yes he might even get lucky enough to have ford do it. hed have to buy the delete kit obviously but he may luck out and get them to put it on. by the way whats a "tar kettle"
Old Jun 23, 2010 | 06:53 PM
newman's Avatar
WHat color is the smoke?
Old Jun 23, 2010 | 09:44 PM
Mdub707's Avatar
Yes, what color is the smoke? I never even noticed that when I responded, I just assumed black smoke and I don't know where the heck I got that from...
Old Jun 24, 2010 | 05:34 AM
94dizzyram's Avatar
The smoke is black with a tinge of blue.
Old Jun 25, 2010 | 04:08 PM
94dizzyram's Avatar
Thanks for the help guys. Ended up being the egr valve after all. They said it was stuck open. I assume they either replaced or cleaned it up. I told the boss that if it ever did it again he should just delete it. Are there any downsides to deleting it.
Old Jun 25, 2010 | 05:51 PM
newman's Avatar
It won't pass emissions if you delete it.
Old Jun 28, 2010 | 08:19 PM
94dizzyram's Avatar
no emissions here yet. knock on wood. They said they unhooked it.
