Need help> 91.5 w30 has no power
Old Jun 23, 2010 | 12:41 AM
talanwilson's Avatar
Question Need help> 91.5 w30 has no power
I have a stock 91.5 W350 and it has no power. By the time it starts to make power, its time to shift gears, what can I do to improve the performance?
Old Jun 23, 2010 | 12:53 AM
bobcat67's Avatar
turn up the pump
Old Jun 23, 2010 | 12:55 AM
Originally Posted by bobcat67
turn up the pump
if i add more fuel will it spool up faster?
Old Jun 23, 2010 | 01:08 AM
bobcat67's Avatar
yes, that is the main intention by adding more fuel the turbo will spool up faster, to much fuel though and it'll just melt the turbo down and possibly not spool much at all
Old Jun 23, 2010 | 01:12 AM
any idea how far i can turn the fuel screw and get peak performance and still stay safe?
Old Jun 23, 2010 | 04:10 AM
RSWORDS's Avatar
You really need to get gauges first.... BUT as a guideline usually your OK if you turn the screw to the collar... usually... I would get gauges first though.
Other things like a smaller exhaust housing will help spool up more then messing with the full power screw but not really give you much more power. Also look into a 3200 spring, that will allow you to hold the gear longer and carry more boost into the next gear. I would go...
Gauges
Fullpower screw
3200 Spring
Exhaust housing/turbo
Performance Fuel Pin
Clutch....
Old Jun 23, 2010 | 08:18 AM
Budgreen's Avatar
3200 spring will wake it up, night and day difference driving it.
Old Jun 23, 2010 | 09:42 AM
NadirPoint's Avatar
Absolutely. If I could do only one mod to a stock truck that would be it - especially a stick.
Old Jun 23, 2010 | 02:03 PM
Budgreen's Avatar
agreed, with our massive turbo exhaust housing it won't spool at stock rpm's
Old Jun 23, 2010 | 02:20 PM
big bad diesel 416's Avatar
Site Sponsor
https://www.dieselbombers.com/1st-ge...en-sticky.html
