Estimated HP ?
Old Jun 22, 2010 | 02:25 AM
angelic0-'s Avatar
Default Estimated HP ?
Ok, i don't know if my truck came with a tuning from the dealer that originally sold it, but it's listed as a 230hp in the registration placard....
So far the wastegate has been plugged, removed the silencer ring (not sure if it changes anything but the sound) and free flowing 3" exhaust...
If i mod my fuel plate to #100 or #10 ? what do i get ?
How do get my turbo to light sooner, do i have to crank the wheel ?
Old Jun 22, 2010 | 07:20 AM
tpcdrafting's Avatar
Removing the silencer ring doesn't do anything but make more noise.
3" exhaust isn't going to do much either. 4" minimum. Remember, adding fuel to your 12 valve is the easy part. Cool air in and hot air out is critical for being able to use that fuel effectively.
Slide your AFC housing full forward, this will help it spool sooner, but won't really add any power.
Plugging the wastegate doesn't do anything SOP in my opinion.
Carving your stock plate to a 100 will help significantly, how much HP you make from that depends on so many other things.
You will have to adjust your star wheel to a level of smoke you can tolerate, but it will also help with spool time. Adjust it out/in to the sweet spot you like. I've found this also can affect mpg. It takes a lot of trial/error to get it where you like it.
Good luck with it!
Old Jun 22, 2010 | 01:43 PM
85_305's Avatar
Being Evaluated
The only thing blocking your WG is doing is setting you up to blow that turbo to smitherines.
A 100plate, with the afc and plate slid forward and some tuning combined with an intake and exhaust will prolly be around 350-380hp and 700-800lbs of tq with the 5spd.
Old Jun 22, 2010 | 06:20 PM
cummins95's Avatar
with just a plate??? i think your estimations are a bit inflated... i highly doubt its even to 300 horse.
get urself an intake and 4 inch exhaust n let that beast breathe!! haha
Old Jun 22, 2010 | 07:07 PM
captain_stabbin's Avatar
yea a BIGGGGG NEVAGTIVE ON THAT ONE GHOST RIDER i can promise you that by doin all that to it will not make nowhere near 380 sorry. more like 240
Old Jun 22, 2010 | 09:47 PM
85_305's Avatar
Being Evaluated
You guys been smoking wayyyy too much crack if you think a plate/intake/exhaust/tuned afc will only give you 25hp. Way too much crack.
Old Jun 22, 2010 | 09:49 PM
who said anything about 25 hp?
Old Jun 22, 2010 | 09:52 PM
85_305's Avatar
Being Evaluated
Since my truck came stock with 215hp, and you figured it would make 240 hp, thats about a 25hp difference
Old Jun 22, 2010 | 10:01 PM
cumminspwr11's Avatar
the orginal poster has a 95 which is the 160 or 180 pump depending on auto or manual i believe, and i know a #100 gives you ROUGHLY 100hp depending on where its positioned and what not and if you have enough air for all the fuel, so i would say the 250-280hp range is a safe area to suggest, just my 2cents
Old Jun 23, 2010 | 09:09 AM
85_305's Avatar
Being Evaluated
he has a 5spd.. which means he has a 175pump and 420tq. With an intake, exhaust and some good afc tuning, he can def. be in the 3-350hp range.
