how can i tell?
Old Jun 22, 2010 | 12:50 AM
wyodiesel92's Avatar
Default how can i tell?
if my lift pump was replaced with an in the tank one without dropping the tank?
Old Jun 22, 2010 | 07:41 AM
RAW's Avatar
RAW
Mine had a relay near the left hood hinge. A wire harness from it ran down along the frame rail to the tank, another to the engine harness, and another wire to the battery. If you find and trace the wires from the factory engine harness lift pump plug you should get your answer. It is a square 2 pin plug located behind the fuel filter. That is also the location of the block mounted lift pump, if you have one.
Old Jun 22, 2010 | 10:05 AM
Thanks! I'll take a look
