4x4
Old Jun 20, 2010 | 08:42 PM
cumminsCrazy's Avatar
Default 4x4
are vaccum lives both supposed to be sucking at the same time?
Old Jun 20, 2010 | 10:05 PM
angelic0-'s Avatar
not to thread jack... but my 4x4 doesn't actuate..... front axle doesn't work.... can i be experiencing the same problem as cumminsCrazy ?
Old Jun 20, 2010 | 10:23 PM
toy4xchris's Avatar
the 4x4 front ends are notorious for acting up I am not sure about the vacuum on both lines but there was a company that made a cable pull replacement for the vacuum actuators.
Old Jun 20, 2010 | 10:30 PM
cumminspwr11's Avatar
one line sucks at a time, they move a diaphram back and forth to unlock and lock 4x4, check ALL you lines for leaks, i had the same problem with it only wanting to work some times so i took all the lines for the t-case and 4x4 out and got two egr valve shut offs form a pontiac grand am and wired up a switch in the cab, doesnt cost near as much as the cable set up and you can get all the parts at napa, i have to abilty to have 2 wheel high or low and 4x4 high or low, 2 wheel low works great for backing up heavy trailers up steep grades
Old Jun 20, 2010 | 11:57 PM
angelic0-'s Avatar
I was thinking this over today because i have been using 2WD LO for backing up when i have to be really accurate
Old Jun 21, 2010 | 10:01 AM
the posi- loc cable kit looks pretty sweet i think im going to do that insted of messin with the vacuum lines
Old Oct 18, 2010 | 10:45 PM
big bad diesel 416's Avatar
Site Sponsor
got any pics or more info?
Old Oct 19, 2010 | 06:10 AM
monster12valve's Avatar
i had the same issue... it ended up being a vacume leak in the line that runs above the engine under the rubber that seals the hood by the windshield cowl
Sep 15, 2015 07:40 AM
Feb 24, 2015 04:00 PM
Dec 7, 2014 11:20 AM
mabr0503
Nov 27, 2014 01:36 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
