D-tech turbo \ Fireball injectors
Old Jun 20, 2010 | 06:00 PM
01ram2500's Avatar
Question D-tech turbo \ Fireball injectors
Im new to the bomers, was wondering if any one is running the 150 Fireball injectors ? I was also wondering about the D-tech turbo do they make the fatshaft in a 64/14 and is any one running one ? Thanks for the help.
Old Jun 20, 2010 | 06:06 PM
Diesel Power Source makes a DTech Turbo in 62/65/14 and a 64/65/14. We have serveral customers running Fireball Injectors. Turbo20psi is running Fireball 150's and a Phat Shaft Turbo.
Luke
Old Jun 21, 2010 | 02:21 PM
kingbrad89's Avatar
I heard negative things about the d tech turbos. I talked to one of the guys at alligatorperformance.com (when i was in the market for a turbo) who said that they are made in china and have a tendency to melt down under moderate competition type applications. He said there is poor consumer feedback, and many many returns to the manufacturer. Plus, apparently you cant understand what they are saying if you do have to call the manufacturer.
Old Jun 21, 2010 | 07:09 PM
01ram2500's Avatar
thanks for the info , but what about fireball injectors ? I would like to talk to someone who is running them .
Old Jun 21, 2010 | 07:28 PM
RAW's Avatar
RAW
I have Fireball 65's, and I love them! 7 holes, instant starts, does not smoke on winter days when fired up, very smooth. If I keep the needle at about 105km/h, I can get 25MPG.
Old Jun 21, 2010 | 07:33 PM
Lil Red Express's Avatar
I have the Fireball 40's and really like them.
Old Jun 21, 2010 | 08:39 PM
turbo20psi's Avatar
I Have the fireball 150s and love them with a phat shaft 64/14.Increased mpg,the truck idles great NO MISSING what so ever.Egts running down the road 2000 rpm 680 degrees before turbo.But the fuel is there when you need it.Call luke he will set you up with what you want to do with your truck.
Old Jun 21, 2010 | 09:38 PM
kingbrad89's Avatar
Turbo20psi, it sounds like you are satisfied with the fireballs and your 64/14. I have the super b special which is also a 64/14... Are you happy with the spooling? Do you tow? I have 150 jammers and im looking to reduce my egt's and pick up some spool time by going with a better injector. What max egt at WOT do you see?
Old Jun 22, 2010 | 11:26 AM
turbo20psi's Avatar
I am happy with the spool time(note I have a cam in the truck to).I do tow sometimes its not much weight 6,000 pounds.The max egt I remember seeing was 1500 degrees WOT edge drag comp set on kill,pump tapped before cam install.
Old Jun 22, 2010 | 05:27 PM
kingbrad89's Avatar
Default D-tech turbo \ Fireball injectors
Yeah, I would love to cam my truck...
