raptor 150
Old Jun 20, 2010 | 10:56 AM
wyodiesel92's Avatar
Default raptor 150
How well does this work on keeping fuel pressure? Also how hard of an install is it, from what I saw looking them up for prices its supposed to be easy and you don't even have to drop the tank? Just curious if this is going to be a big job or something I can do with basic tools in my front yard.
Old Jun 20, 2010 | 12:17 PM
12vcummins96's Avatar
very good on fuel pressure and if you got some mechanical exp. you will do fine
Old Jun 20, 2010 | 02:49 PM
00' Quad Cab's Avatar
Easy install, depends on how you go wether you have to drop the tank or not.
I dropped mine so I could run all new fuel line, a draw straw would help in the long run.
Got mine here:Vulcan compound turbo components, AirDog Systems, FireBall injectors, DrawStraw? Big Line Kits, VP silicone boot kits, gauge installation components, metric adapters & fittings, FASS, Quadzilla, Edge,AirDog, DTT Trans, ISSPRO, HTT Turbo, AFE, Veg pu but any of the site sponsors are great to deal with.
Old Jun 20, 2010 | 03:10 PM
I'm unsure if I need to get the draw straw for mine, on that site it didn't say much. I'm not completely sure if I need to drill a hole in my tank or not for the draw straw and if I need to get the special one with the return line.
Some one please chime in I'm clueless at the moment on this
Old Jun 20, 2010 | 04:18 PM
Read through this, it will help:fittings & adapters
Old Jun 20, 2010 | 04:45 PM
If you go with the 150 I would do the draw straw.
Old Jun 20, 2010 | 07:15 PM
Yeah I'm planning on doing the 150 and after reading that I'm guessing I need the draw straw I. Ill have to check the sticker under the hood to see if the previous owners upgraded to an in the tank pump
Old Jun 20, 2010 | 09:29 PM
dodge rodder's Avatar
i have the raptor 150 and very happy with it not a problem so far. the oonly thing is i did ent use the draw straw on mine, wasent sure if i needed to
