failure codes for a vp 44 injection pump
Old Jun 19, 2010 | 04:56 PM
mudmaniac's Avatar
Default failure codes for a vp 44 injection pump
I have a 2000 Dodge 2500 with an afe intake, edge juice with attitude and 4 inch exhaust that died yesterday, and will not start. I read the codes and came up with three, p1689 (controller area network bus failure), and p 1688 (internal fuel injection pump controller failure), and the third p0252 (injection pump fuel metering control A range/performance. I searched and found that the p 1688 code meant injection pump failure but i couldnt find much about what the p1689 or p0252 mean. I guess its time for a pump but i was just curious about the other two codes, any help would be appreciated.
Old Jun 19, 2010 | 06:26 PM
Billy D's Avatar
There's a thread somewhere with the listing of codes. I'll keep looking, someone will find them
Old Jun 19, 2010 | 06:40 PM
P0252 is Injection Pump Fuel Metering Control "A" Range
I can find P1698 - are you sure its that one?
Codes: https://www.dieselbombers.com/codes.php
Yeah, you very likely need a VP-44.
Have you cleared the codes and they came back? Sometimes they can hiccup and throw a couple of codes and you clear them and its ok. But unfortunately, that doesnt often happen with VP-44 related codes.
Do you have a fuel pressure guage in the cab? You having dead pedal symptoms?
Old Jun 19, 2010 | 09:50 PM
turbo20psi's Avatar
P1689 No Communication Between ECM
and Injection Pump Module Fuel Pump Relay in the PDC is damaged or missing .
Old Jun 20, 2010 | 01:48 AM
mudmaniac's Avatar
I did try to clear the codes, cleared p1689,p0252, but the p1688 is still there. I tried to crank it again after clearing the codes, but still no luck.
No dead pedal symptoms. The edge has a fuel pressure guage and it was reading in the 14psi range at 2000 rpm. I had been driving the truck for about two hours when I stopped at a store and shut it off and it wouldn't crank.
Old Jun 20, 2010 | 09:34 PM
dodge rodder's Avatar
my dads did the same thing yesterday, we r going to put in a new pump when we get a chance
Old Jun 20, 2010 | 09:40 PM
DB Admin's Avatar
Banned
my death code was P0216
Old Jun 20, 2010 | 09:48 PM
turbo20psi's Avatar
P1688 Internal Fuel Injection Pump
Controller Failure .
Th electronics are fryed.
Old Jun 23, 2010 | 09:40 AM
jkidd's Avatar
You will need a new pump friend. Hopefully you were not far from home when it happened.
Old Jun 23, 2010 | 09:43 AM
12vcummins96's Avatar
yep the pump is a gonner
