ok boys... tell me what's wrong.
Old Jun 19, 2010 | 02:43 PM
luv4rotties's Avatar
Southern Redneck Girl
Default ok boys... tell me what's wrong.
For the last week, my truck thinks the key is in the ignition when it isn't. door won't lock, radio stays on with the doors open....and it dings like the door is open even when it's not....doesn't do it everytime I cut it off, but it does it alot and it's getting downright aggravating.
could be an ignition switch short.. or short in the steering column I know.. but how to make it stop is what I need to know....I've done everything from turning the key off and on, to tilting the wheel, to starting it back up.....etc..... HELP!!
Old Jun 19, 2010 | 03:14 PM
dangerous1965's Avatar
Spray some lube in the key hole and put the key in and out alot wiggle it around see if that helps. If it thinks a door is open check the door sensors for a short or break.
Old Jun 19, 2010 | 10:05 PM
lube in the key hole??? seriously?? the key doesn't stick.... wow lots of answers on here ... it don't think the door is open.. it thinks the key is still in the ignition when it isn't. it's not throwing any codes either.
Old Jun 19, 2010 | 10:42 PM
captain_stabbin's Avatar
sounds like a common wire problem! sina i wish i knew, my guess would be bad ignition!
Old Jun 19, 2010 | 11:35 PM
12vcummins96's Avatar
ok im gonna chime in the body control modules in these dodges are junk it needs to be put on a scanner to check for body control codes hun call me i will help you out sweety
Old Jun 20, 2010 | 10:41 AM
A little lube never hurt anything! Seriously I was thinking the pin inside was getting stuck! Start simple work your way up!
Old Jun 20, 2010 | 02:55 PM
00' Quad Cab's Avatar
Mine did this at one time, the suggestions about the lube are right on for the fix I needed.
Old Jun 20, 2010 | 03:37 PM
NadirPoint's Avatar
TIPM (Total Integrated Power Module) Should stand for: Totally Irrational Piece 'o Manure.
Old Jun 20, 2010 | 06:32 PM
Thanks guys for the input.....it only does it when I'm by myself and in a hurry... go figure on that one.. when Kevin is in the truck with me... it won't do it. Damn truck hates me.
I'll try the lube... and go from there. Troy I'll call you too
Old Jul 8, 2010 | 02:13 PM
AABEAR's Avatar
Try dissecting the BAT's for 10 mins then replace. This some time will fix it.
Sep 21, 2015 06:10 PM
jjbced
Jul 19, 2015 10:03 AM
Bob V
Apr 6, 2015 11:02 PM
nelly559
Feb 2, 2015 08:19 AM
cutthroatxxx
Nov 16, 2014 09:11 PM
