need help quickly
Old Jun 18, 2010 | 11:51 PM
1slow24's Avatar
Default need help quickly
hey i got a pump for my truck from a guy for nothing and was wondering if i should remove the factory pump when i go to do it?..it is my daily driver so i dont want to mess anything up
Old Jun 19, 2010 | 12:00 AM
captain_stabbin's Avatar
so what your asking is, should you put the pump you just got on your truck?
Old Jun 19, 2010 | 12:35 AM
Need a bunch more info here.
Old Jun 19, 2010 | 01:46 AM
gpandlf's Avatar
Agreed
Lift pump??? If you got a raptor or fass or something, you can just leave the stock one on the side of the engine if you want, it is bypassed but its jusy extra weight imo...
Old Jun 19, 2010 | 10:22 AM
1slow24's Avatar
no i am asking can i leave the one in the tank... sorry for lack of info i had a rough night last night.. i got a pump and would like to put it on today but mu only question is do i gte rid of the pump in the tank from the factory and mount mine on the framerail. once again i apologize for the bad first post
Old Jun 19, 2010 | 10:33 AM
01quadcab's Avatar
what pump do you have to put on? Your going to need to drop the tank at some point and put in a draw straw or sump, if that is where yours is. Only ones that have them in tank were dealer fix's that didn't work. So just be sure you have one in there.
Old Jun 19, 2010 | 10:38 AM
^^ what he said ^^
Have to drop the tank to take the junk pump out or install a Vulcan Performance Drawstraw V, or this: http://www.vulcanperformance.com/Dra...w-p/jlfmds.htm
Old Jun 19, 2010 | 11:52 AM
moparious maximus's Avatar
Maybe its just me but I think its easier to pull the box off to get to the tank then to pull the fuel tank by itself.
Old Jun 19, 2010 | 11:53 AM
1slow24's Avatar
That's what we are gonna do
Old Jun 19, 2010 | 12:12 PM
RAW's Avatar
RAW
At one time, I had the factory POS in the tank and a block mounted pump. It had lots of flow, too much though. 29PSI at idle, and dropped to about 22PSI at WOT. If you have a rail mounted pump with a regulator you may be able to get away with keeping both, otherwise I think you will run into the same high pressure issue as I did.
Josh923
Sep 10, 2015 11:16 AM
