oil in turbo ?
Old Jun 18, 2010 | 07:12 PM
stock 24 v's Avatar
help oil in turbo ?
what's up bomber buddy's,
i removed my air filter and tube
and where the silincer ring goes there is oil
a bad sign or... what ??. thanks guys
Old Jun 18, 2010 | 08:34 PM
RAW's Avatar
RAW
You may want to check the outlet side of the turbo as well, and see how much oil is there. Of course it's never a good thing to find out outside of its proper place, but according to our local Ford dealerships, "a little oil in the intake is ok". But that's a Ford "technician" for you. The seals in the turbo may be going out, causing oil to leak past the shaft. It would be a good idea to keep an eye on the oil accumulation in the turbo. If you are concerned about it they can be rebuilt. If your handy enough you can buy the kit and do it yourself, or pay a shop to do it.
Old Jun 18, 2010 | 08:39 PM
turbo20psi's Avatar
How many miles is on the turbo?Oil on the intake side is not good.You may want to check shaft play also?
Old Jun 19, 2010 | 10:15 AM
crazycooter's Avatar
on the ford opinion... it is normal, because fords route the pcv through the intake
btw, whats it cost to get a turbo worked over?
Last edited by crazycooter; Jun 19, 2010 at 10:15 AM. Reason: Automerged Doublepost
Old Jun 19, 2010 | 02:01 PM
00' Quad Cab's Avatar
You say you have an aftermarket filter on a home made intake?
Is it an oiled filter? (AFE, K&N etc.?)
The filter may just be over oiled if that is what you are running, noticed a little oil in my turbo once, cleaned it out and ran the stock intake with a new filter for about a month and all was dry. Re-installed my AFE and backed off the oil a little when I serviced it, all good now.
Old Jun 19, 2010 | 05:06 PM
stock 24 v's Avatar
the oil is just inside the front turbo housing ,
it is a k&n cone filter , i cleaned it up pretty good
so i will check it later to see how bad it really is
i keep u posted.
avatardvr
18
Aug 8, 2019 12:38 AM
honda89
Oct 17, 2015 01:08 PM
rodbuilder
Jun 26, 2015 12:48 AM
CumminsCoalRoller24/7
Apr 21, 2015 09:03 PM
MrCat4974
Mar 25, 2015 08:13 PM
