Holly black fuel pump
Old Jun 18, 2010 | 03:34 PM
hiboy_76's Avatar
Default Holly black fuel pump
I bought a holley black fuel pump and its rated for 140gph and 14psi. Do i need to ruun a reulator? because my buddy told me i needed to have one or run it through the stock lift pump. Why would i have to do that? Thanks.
Old Jun 18, 2010 | 06:21 PM
NadirPoint's Avatar
No, you don't need a regulator and I would definitely NOT run it through a stock LP. That's a good way to fill your crankcase with fuel if the stock LP diaphragm fails.
Old Jun 18, 2010 | 06:40 PM
tltruckparts's Avatar
x2 thats about the right pressure for the pump and definitely not run it through the lp. the only problem ive heard about the holley lift pump is the seals arent rated for diesel fuel and get eaten up. i dont know how true this is but it wouldnt hurt to replace all the orings with some diesel rated ones
Old Jun 18, 2010 | 06:41 PM
RSWORDS's Avatar
Yep. 14 psi wont hurt your pump at all, they can take up to 18psi without issue and as NadirPoint said is your diaphragm fails you will fill your crank case and destroy your engine if you don't catch it right away.
Old Jun 18, 2010 | 07:08 PM
NadirPoint's Avatar
I've had a Procomp black (Holley knockoff) on my aux tank for three years, no issues yet. The only thing I don't like about those pumps is they are loud. That pump gets used to transfer the last few gallons to the stock tank after the aux tank runs low and to transfer kerosene a couple times each winter.
Old Jun 20, 2010 | 08:19 AM
hiboy_76's Avatar
Thanks guys!
I called summit racing before i bought it and they said its good as long as i dont run biodiesel in it.
Another question. I put my 3200 gov spring in my truck. it runs 10 times better, buy my top speed is only 90mph. with the stock spring it was 85mph. Do i need more fuel? I only have it turned up about 1.5 turns.
Old Jun 20, 2010 | 08:25 AM
NadirPoint's Avatar
Probably needs more throttle travel to get full fuel.
Old Jun 20, 2010 | 03:07 PM
hiboy_76's Avatar
i took the full throttle screw out
Old Jun 20, 2010 | 03:18 PM
NadirPoint's Avatar
Just because the screw's not there doesn't mean the throttle is getting full travel. Have you had somebody sit in the driver seat and floor the go pedal while you watch it? What about moving the cable up to the middle hole on the throttle lever? They are also known to bottom the lever out on the fuel inlet before full travel.
Old Jun 20, 2010 | 03:24 PM
hiboy_76's Avatar
i havent tried that. I'll get back with ya when i do.
