2006 powerchoke pops
Old Jun 18, 2010 | 01:36 PM
Blake's Avatar
Default 2006 powerchoke pops
i have a 2006 E450 with a 6.0 powerstroke.At idle i have a severe popping/boom noise comming from my intake.The truck isnt misfiring but i have had the turbo,injectors,intake,ficm,convertor,exhaust back pressure pipe and sensor,map sensor and hose,egr and egr cooler,fuel filter's,high pressure pump replaced and still no fixing for this.its a loud pulsating pop/booming noise.i have spent alot of money trying to fix this and now im ready to burn the truck down.....if anybosy has a suggestion please let me know...
Old Jun 18, 2010 | 01:55 PM
DIESELDENT's Avatar
Welcome to db
Moved to the powerstroke secton
Old Jun 18, 2010 | 04:11 PM
Mdub707's Avatar
Why did you replace all of that stuff anyways? Throwing money at it blindly doesn't seem like the best way to go about it. It needs to be properly diagnosed. We don't have enough information to even get started here. When did it start, how many miles on the van, what is it used for and how often? Any mods?
Did something else happen with it that you replaced all of that stuff?
Old Jun 19, 2010 | 05:59 PM
npccpartsman's Avatar
The only thing I didn't see you mention was heads/valve train. It's possible you have a stuck valve. You need to run a compression and/or leak down test. Is it throwing any contribution/balance codes?
regitan
Big Rigs & Semis
May 24, 2015 10:23 PM
Dec 17, 2014 08:20 AM
Dec 15, 2014 01:10 PM
Oct 24, 2014 02:50 PM
