new pyro where to tap exhaust manifold?
Old Jun 17, 2010 | 10:57 PM
crazycooter's Avatar
Default new pyro where to tap exhaust manifold?
I just bought a set of guages and figured I should get some info from the pros. what is the best place to mount the sender unit to the most accurate read from a pyro??
Old Jun 17, 2010 | 11:07 PM
Lil Red Express's Avatar
Where the turbo mounts to the manifold there is a center divider inside the manifold. drill and tap in the back half of that section. The back 3 cylinders run the hottest so that is the best place to put it. Is this as clear as mud for you?
Old Jun 17, 2010 | 11:20 PM
that mud is so clear I can see right through it thanks.
Why do 456 run hotter than 123?
Old Jun 18, 2010 | 07:38 AM
RAW's Avatar
RAW
Because those 3 cylinders are further away from the air intake horn, and don't get as much air as 123, as the air has to travel further.
Old Jun 18, 2010 | 09:26 AM
that makes sense, thanks
Old Jun 18, 2010 | 06:23 PM
thebullet83's Avatar
and coolant has picked up heat before it gets to the rear of the block
Old Jun 18, 2010 | 07:29 PM
Thanks for the diagram DM. Thats exacly what i was hoping someone would post.
Old Jun 18, 2010 | 08:09 PM
DB Admin's Avatar
Banned
he needs to put grease on the drill bit to catch the shavings
Old Jun 18, 2010 | 08:47 PM
I have used WD-40 with no problems.
Old Jun 18, 2010 | 08:51 PM
RAW's Avatar
RAW
I believe he is suggesting to use grease so it will grab all the metal fragments when you drill and tap. Therefore keeping them out of the turbo when you fire it up for the first time.
