a/c, heater fan
Old Jun 17, 2010 | 10:22 PM
mb5n537's Avatar
Default a/c, heater fan
ok havnt worried about it untill now because i didnt have a/c but got it workin so want it fixed, my fan speed control on the dash only works on low and high, the two settings in the middle dont work, anybody else had this problem?
Old Jun 17, 2010 | 11:34 PM
tiremann9669's Avatar
Reistat probably not spelled right, I believe on the dodges they are on the heater box, it's just a little box that has several wires going to it.
Old Jun 18, 2010 | 07:37 AM
RAW's Avatar
RAW
A good place to start would be the resistor pack, they are notorious for failing in any breed of truck. Mine had full blast only until I removed the resistor pack and re-soldered a tab back in place.
Check the wires leading to the resistor pack as well, make sure a different wire has power on different settings of the switch. Hope that helps.
Old Jun 18, 2010 | 10:30 AM
24vcumminscowboy's Avatar
do you have to tear into the dash to get to the bower ive got the same problem
Old Jun 18, 2010 | 10:40 AM
RAW's Avatar
RAW
You don't have to at all. The blower motor and resistor pack are both located on the passenger side, and are removed/installed from the bottom. I believe there are 4 screws for the blower, and 3 for the resistor pack. Very easy to remove and install.
Old Jun 21, 2010 | 10:29 PM
mb5n537's Avatar
alright thanks, ill look at it and see if that helps, hope it does.
Maclain Marsh
Jul 13, 2015 06:23 PM
Rbear
May 3, 2015 07:47 PM
robbyS
Apr 16, 2015 02:22 PM
Mike H
Jan 25, 2015 10:08 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
