sputtering
Old Jun 17, 2010 | 06:59 PM
crzycummins's Avatar
Default sputtering
the truck listed in my sig....just installed a vp and the airdog about two weeks ago. every now and then when i stop and go suddenly and or take a corner from a stop and go it sputters briefly and then its fine..no codes. any ideas?
Last edited by crzycummins; Jun 17, 2010 at 06:59 PM. Reason: Automerged Doublepost
Old Jun 17, 2010 | 07:29 PM
RAW's Avatar
RAW
Did you put a draw straw in?
Old Jun 17, 2010 | 08:05 PM
i did..cut it as close as i could to the bottom and then some because the tank will sag a bit when in and heavy. cut notches out in it too.
and ive got alot more than a half tank at all times
i dont know the fuel pressure at the moment...waiting on the new sensor for my jwa to get here bc the other was bad
but i did take the fuel line loose and just check it in a manual way and it has pressure like crazy to the vp and to the injectors
Last edited by crzycummins; Jun 17, 2010 at 08:05 PM. Reason: Automerged Doublepost
Old Jun 17, 2010 | 08:08 PM
RAW's Avatar
RAW
How's the fuel pressure before, during and after?
Oops, didn't see last post.
Old Jun 17, 2010 | 08:10 PM
DB Admin's Avatar
Banned
did you install the airdogs warning light ? that thing reads right off the pump and works perfectly
Old Jun 17, 2010 | 08:17 PM
no i didnt chad...i guess all of the things ive seen about the warning light coming on when its not needed turned me off. i should have the new sensor tomorrow and if its not here then im gonna install my old fpg until it does...it runs perfect all the time except the times i noted...im scratchin my head here
every other time i have the darned thing right how i want it except for just those few moments but as we all know its those little blips that drive us crazy
Last edited by crzycummins; Jun 17, 2010 at 08:17 PM. Reason: Automerged Doublepost
Old Jun 17, 2010 | 09:58 PM
turbo20psi's Avatar
Did you do a APPS reset when you put the new vp in.Every time I do a VP in a truck I reset it for good measure to adapt to the new pump or replace if needed a new APPS.If you do a reset take any programmer (edge,smarty,etc.) off line.
Old Jun 19, 2010 | 09:57 PM
how do you reset an apps? never done that before?
Old Jun 19, 2010 | 10:03 PM
Whit's Avatar
Site Mascot
turn key on but dont start
slowly press accelerator pedel to floor
slowly let pedel back up
turn key off
start truck.......apps is re-calibrated
Old Jun 19, 2010 | 10:09 PM
turbo20psi's Avatar
Thanks whit.
