Running Too High EGT's - Water/Meth?
Old Jun 15, 2010 | 08:18 PM
DB Admin's Avatar
Banned
Default Running Too High EGT's - Water/Meth?
Ok so with the new quad tune my pyro is about 1000* all the time , Is there any set backs to water/meth lonjevity wise? increase fuel mileage? which kit to get ?
Old Jun 15, 2010 | 08:23 PM
dirt diggler's Avatar
Kenny i guess knows alot about the water meth so im told
Old Jun 15, 2010 | 08:29 PM
DB Admin's Avatar
Banned
ill give him a call , i found this ... pretty impressive
DYNO RESULTS: '04 CUMMINS EFFECT OF WATER-METHANOL CONCENTRATIONS
RWHP TORQUE
Stock 279 hp 580 lb-ft
Baseline (with Edge EZ) 379 hp 766 lb-ft
Windshield washer fluid 429 hp 873 lb-ft
50 percent methanol 453 hp 930 lb-ft
75 percent methanol 487 hp 960 lb-ft
Old Jun 15, 2010 | 08:40 PM
i found out it is very trickey to get it set right i would say that you would need a dyno on hand when setting the system up to see were your gains would be on the settings. As a matter of fact i still dont have mine figured out but i got it set to were the motor sounds like it not gettin to munch to quick. o well
Old Jun 15, 2010 | 08:42 PM
DB Admin's Avatar
Banned
i just want a little bit to cool me down dont need any more hp and dont want to decrease longevity
Old Jun 15, 2010 | 09:13 PM
J-Pipes's Avatar
If your going to ask Kenny, he is working 2nd shift this week, so you'll need to call him before 1:00. Good luck, I would like to put some on my truck eventually
Old Jun 16, 2010 | 12:05 AM
I wouldn't run over a 50% Mix.
Old Jun 16, 2010 | 02:01 AM
bobcat67's Avatar
I'd get the Snow performance kit with the big ol 7 gallon tank so you don't have to worry about it emptying itself on a couple hard runs or something, buddy of mine had it on his dmax and would go through a windshield washer reservoir in 2 1/4 mile passes
Old Jun 16, 2010 | 12:29 PM
mxtuner1's Avatar
Make your own kit, DM, and you will be happy. Remember methanol/water mix the more water the more cooling. So you can batch up your own mixture (here a 55 gallon 99+% pure methanol delivered to my garage is only $130.00)- and if towing use more water ratio. I would use even straight water if egt's are too high. But for power - the chemical sites say that methanol/water miscibility burn ratio is best at 65/meth 35/water for power. Above that is wasting meth. I would think a 2 stage system ran with 2 selenoids first one small jet for mileage set at 1 lb boost and second set larger jet set at 7lbs boost for more power when needed. You would get mileage and power that way. PM me if you want help with the kit.
Old Jun 16, 2010 | 01:42 PM
Share the info - Im sure some of our other members would be interested too.
