What Can You Stack With The Edge With Attitude
Old Sep 28, 2007 | 02:24 PM
STROKER400's Avatar
Default What Can You Stack With The Edge With Attitude
Just what the title says. I am going to unlock the hot code yet but was just woundering what can i stack this kit with.
Old Sep 28, 2007 | 02:56 PM
STROKER400's Avatar
Thats funny i just tried calling dieselgawgs performance got a machine. do i need to up grade my turbo first and lets say this if i stack it what all do i need to do yet injectors turbo i am new to this world of power but love it and would like a 500 hp rear wheel truck i would think i am close to 400 now as i am told
Old Sep 28, 2007 | 03:05 PM
I saw that you had called me I was on the other line talking to my warehouse. The Edge Juice or Comp / Smarty Stack works the best on the VP44 Cummins but there still are alot of people that use this stack on the Common Rail Engines..... Unless you are wanting massive HP your stock injectors will work just fine. Your next upgrade will probably need to be your Transmission.
Old Sep 28, 2007 | 11:30 PM
cummin_un_glued's Avatar
FormerVendor
i've personally ran the edge hot juice / smarty stack on my 06 and i wasnt impressed, the smarty even had the "wild torque" downloaded to it, the only thing i did notice was the low end power but it fades away around 2300rpm which is right in the heart of your power......i'm running a TS MP8 with my edge and i love it.....the edge does timing and duration so if you run the smarty you can only run it on the even setting which do not add timing and since the smarty dosnt add rail pressure which leaves out a paramater that you can modify, then you are just adding more duration which is going to make it smoke more but not necciarly add that much more power.....the mp8 is rail pressure only and it is infinatly adjustable so if you have a RP gauge you can actually dial in exactly how much pressure you want to add and since you are not doubling up on any of the 3 paramaters then i feel like you get more out of it....i had all 3 of them on my truck at the same time and it felt like the smarty was overriding the edge, i couldnt tell any difference when i would change edge levels, the smarty was loaded on sw 8 .....you will need a fuel pump tho to keep up if you upgrade to the hot code on the edge....which i see you dont have it and i know its a ripoff that edge charges $100 to get the hot code but $100 for 60hp is cheep horsepower....you might want to consider the hot code first and then see if you still want more power, and if you do i would look at the different pressure boxes for a possible stack....ts mp8, dr performance predator, diablo power puck, edge EZ (depending on year) those are all pressure only boxes which all stack good with the edge juice
Old Sep 29, 2007 | 12:11 AM
STROKER400's Avatar
OK thanks i will look into all this its hard so many ideas just dont want to do it wrong. so many diff people saying diff things. for my year truck what is a good fuel up-grade and if i did the hot unlock code and fuel up grade and maybe 100hp injectors would i be happy.after all that then its turbo time.
Old Sep 30, 2007 | 12:58 PM
rufushusky's Avatar
TS MP-8, Edge EZ, Smarty...
Old Sep 30, 2007 | 01:29 PM
FormerVendor
a FASS 150gph would fuel it just fine with the hot code, that is what i'm running with the hot code and mp8 and i can run them both all the way up even 6x5 on the juice and it doesnt run out of fuel.....i think that the hot juice with 100hp sticks would probably net you a few more hp then you would get by stacking a 100hp pressure box with the hot juice but you would almost certainly have to go with a modified cp3 to keep up with the 100hp injectors and if you tow much and still have the stock turbo, you have to remember that you cant turn injectors off so it would be getting very warm on the egt's while towing with the stock turbo and the 100hp sticks, where as with a pressure box you can always turn it down when your towing......either way you go i would suggest that you get a rail pressure gauge and a fuel pressure gauge then you will know what is going on with your fuel
Old Sep 30, 2007 | 05:08 PM
Longhorn's Avatar
I have to agree the Edge EZ makes a real nice stack with the Juice...done it and liked it, I have the EZ now and hope to get the Juice right away to go with it...
Old Oct 9, 2007 | 12:11 PM
skynyrd's Avatar
the smarty won't work with the juice they do not work with each other. the smarty over rides the juice and your juice will not increase the horse power any. what you can run with the juice is a pressure box like an ez, puck, or mp-8 and you can also run a PPE downloader with the juice.
Old Feb 26, 2009 | 02:09 PM
cummins6spd's Avatar
what about running a smarty with an edge comp box...what kind of smoke and power will i get out of that stack?
