Starting problem
Old Jun 14, 2010 | 11:37 AM
Billy D's Avatar
Default Starting problem
Goldie ran this morning exellent as always, then I went back out and nothing. Lights worked, no radio, no nothing, then I put the charger on it, and got some fast clicking, I checked my fuses everything seems ok. What else can I do? Is it my starter? I'm gona pull the alternator and have it checked, along with my battery. Hmmmm, silinoid or starter What to do next... Goldie still won't start after some charger love. I'm always thankful for everyones input
Old Jun 14, 2010 | 11:40 AM
big bad diesel 416's Avatar
Site Sponsor
check your grounds
i know i spent 2 days looking for a bad ground that took 5 min to fix all the probs that ur havin
Old Jun 14, 2010 | 12:59 PM
Billy D's Avatar
I had the Batt and Alt. tested, both were good. Gota starter relay just in case, but came back put the batt & alt in and wrooom, and I didnt replace the relay yet, so its gota be a ground issue. All my grounds seem tights and not crusty, any suggestions on where I should start lookin? Its pissn me off fo sho
bump
Old Jun 14, 2010 | 07:06 PM
Site Sponsor
just for fun run a ground wire to the front grill like 6in from the batt that's what solved all my probs because the batt is grounded to the block and years of oil and dirt make for bad contact to the frame get the picture?
Brice
Old Jun 16, 2010 | 01:14 PM
Site Sponsor
any luck?
Old Jun 16, 2010 | 01:37 PM
Billy D's Avatar
It is gunked up, and I'm going to run that extra ground, thanks for more info! I will be back soon
Old Jun 16, 2010 | 04:04 PM
Site Sponsor
ya man no prob good luck
Old Jun 16, 2010 | 04:11 PM
Billy D's Avatar
Added the extra ground, my alternator tested ok, but you think its not charging? I gotta big honkin 1000CCA battery, and it tested fine too. Goldies running fine, it only gave me the no start once Seems to be ok now
Old Jun 16, 2010 | 09:45 PM
Site Sponsor
test it running with a multimeter
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jmohr52
Nov 2, 2014 08:55 PM
