Gear case cover bolt torque?
Old Jun 14, 2010 | 06:51 AM
tpcdrafting's Avatar
Default Gear case cover bolt torque?
My gear case cover is leaking oil and I'm going to try to tighten it before changing the gaskets, I recall the torque being 18 ft lbs on the bolts, but wanted to confirm with someone with a manual or for sure knowledge, thanks in advance.
Old Jun 14, 2010 | 08:49 AM
Pyro690's Avatar
18 ft lbs is correct.
Old Jun 14, 2010 | 10:50 AM
tltruckparts's Avatar
yup
Old Jun 14, 2010 | 11:48 AM
94 12valve's Avatar
where is it leaking? could be the front oil seal behind the damper
Old Jun 14, 2010 | 09:04 PM
1 can of engine degreaser and the hose and cleaned it off. Drove a few short trips and it's leaking pretty good off the top, pass side and bottom. I'm hoping it's just loose.
Old Jun 14, 2010 | 09:51 PM
94 12valve's Avatar
could be ... did you use a gasket or some RTV when you put it back on?
Old Jun 15, 2010 | 04:11 PM
Yeah, it's been a few years since I changed it when I had the seal behind the case changed. That's deeper into the motor than I am qualified to be doing, so I had that done. It's been leaking for a short while. Out of town right now, I'll check for loose bolts when I get back.
dango
Jun 21, 2016 01:13 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
scrnnmssuck
For Sale
Apr 16, 2015 10:33 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
UC Kid
Oct 23, 2014 05:29 PM
