alternator, voltage regulator or the pcm
Old Jun 13, 2010 | 07:37 PM
tearin_it_up_everywhere's Avatar
Shut Mouth alternator, voltage regulator or the pcm
Okay i have known that my alt was going out for a while. So today i was driving into work for some double time and the gauges went crazy! Showed an over voltage and the speedo was jumping around like a chicken with it head cut off. I have a voltage gauge build in my brake controler so i check that, i had 11.9vdc. Killed the truck running 65mph and it would not restart with the key. So i eased out on the clutch. Fired back up. Got to work it would not even jump start. Changed the hot wire connector on the drivers side and made sure i had a good connection and it would start, after new connector ends and solder. Changed the alt and still it is extreamly slow to pick up the voltage on the new alt after i started it 3 times and check the voltages. I am running yellow top optima batterys. I also load checked them after putting them on the charger for about 45 mins each. Does anyone have any ideas or input?
Thanks Shawn
Old Jun 13, 2010 | 07:40 PM
RAW's Avatar
RAW
I know my alternator won't put out any current until it has had some idle time, a minute or so. If I start the truck, and bump up the idle, it won't break 12.4 volts for about 5 minutes. Weather this is due to the cycling of the grid, or the PCM, I am not sure.
That's what my truck does, if it is of any usefulness.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
jjbced
Jul 19, 2015 10:03 AM
Dan S
Jun 9, 2015 06:55 PM
12valvenation
Jan 26, 2015 12:38 AM
