cummins heater grid
Old Jun 12, 2010 | 12:52 PM
aaronmoore's Avatar
Default cummins heater grid
anyone know how i could hook up heater grid in intake the cummins is in my ford and i donthave the solenoids.
Old Jun 12, 2010 | 01:36 PM
You need the solenoids. I believe Ford starter solenoids will work for this but it will take some buggereing around to get it to work. I believe that youll also need a fusible link between the positive battery terminal and the solenoids.
I would go to www.genosgarage.com - and get a Factory Service Manual. This should have all the wiring diagrams and such to help you out.
What year of Cummins is this? If its a 98 is it a 12V or 24 V?
Old Jun 12, 2010 | 04:06 PM
aaronmoore's Avatar
its a 96 big bump
Old Jun 12, 2010 | 04:24 PM
FastCR's Avatar
You've basically gotta get +12v to the terminals with enough amperage to run them. I believe they are under 40 amps. Nothing too fancy, on/off.
Old Jun 12, 2010 | 04:27 PM
aaronmoore's Avatar
ok thanks
i also seen where people was just getting rid of them with a kit.is that safe.
Last edited by aaronmoore; Jun 12, 2010 at 04:27 PM. Reason: Automerged Doublepost
Old Jun 12, 2010 | 04:36 PM
tltruckparts's Avatar
well since your in texas its pretty warm id assume. they only come on under 60* soemwhere around there im pretty sure. you probably dont need them. and it wont hurt anything to removes them either
Old Jun 12, 2010 | 04:38 PM
Sorry, I missed the part where youre from Texas. You could go with a grid heater delete.
You should be ok with that if temps stay above 30 degrees.
Old Jun 12, 2010 | 04:42 PM
aaronmoore's Avatar
ok thanks guys ill just leave it unhooked i think i found my problem i checked my injectors and 1 and 2 was shootin right after having them cracked open for a couple of secounds but the rest was just pouring out not shootin out like 1 and 2 timing or bad pump maybe?
dodge2014
Apr 16, 2015 08:54 PM
95 cummin
Jan 21, 2015 11:54 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
Oct 31, 2014 08:10 AM
