help cummins white smoke rough idle
Old Jun 11, 2010 | 10:40 PM
aaronmoore's Avatar
Default help cummins white smoke rough idle
i recently installed a cummins 12 valve in my 2004 ford welding truck and it startin white smoking really bad goin down road and has a rough idle.and i took cap off resorvoir and antifreeze was pouring out then it stopped but runs good on high idle.any help will be much appreciated.thanks
Old Jun 11, 2010 | 10:48 PM
Generally slipped timing of the injector pump will cause white smoke.
Old Jun 11, 2010 | 10:54 PM
aaronmoore's Avatar
woud it make it run bad
how would i check the timing? get motor tdc and see if key deal in side of pump fits in slot?
Last edited by aaronmoore; Jun 11, 2010 at 10:54 PM. Reason: Automerged Doublepost
Old Jun 11, 2010 | 11:41 PM
Yeah, that will make it run bad.
The best way is to remove delivery valve holder #1 on the pump and measure plunger lift as you roll the engine over. Then refer to a timing chart.
More detail can be found here: http://dodgeram.info/tsb/1994/18-10-94a.htm
Old Jun 12, 2010 | 12:47 PM
aaronmoore's Avatar
k thanks its worse when its cool outiside and a guy told me this morning i should hook up the heater grid in intake what you think.
anyone know how i could hook up heater grid in intake without the little solenoids cause i put this motor in my ford and i dont have the solenoids.
Last edited by aaronmoore; Jun 12, 2010 at 12:47 PM. Reason: Automerged Doublepost
Old Jun 12, 2010 | 01:37 PM
you didnt say the grid heater wasnt hooked up. that plays a part as well.
Old Jun 12, 2010 | 04:33 PM
aaronmoore's Avatar
o sorry also i just checked the injectors with it running and 1and2 had fuel shootin right but the rest was just pouring
and at first 1 and 2 wasnt shootin right either
would this be timing or pump or what?
Last edited by aaronmoore; Jun 12, 2010 at 04:33 PM. Reason: Automerged Doublepost
Old Jun 12, 2010 | 04:41 PM
That doesnt tell you anything.
Have the timing checked by a shop if you dont have the tools.
Old Jun 12, 2010 | 04:51 PM
aaronmoore's Avatar
ok my buddy has a timing kit ill check it i was just saying that it dont seem like its getting right amount of fuel cause i checked my older one that i got at house and it shoots fuel out when i crack injector lines
Old Jun 12, 2010 | 09:10 PM
Drothgeb's Avatar
Sounds like timing. If you see white smoke while you're driving after a minute or so, it doesn't have much to do with your grid heaters unless it's really cold.
